Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through April 17, 2007
Old     (bbking)      Join Date: Dec 2006       04-12-2007, 8:47 PM Reply
i got a longsleeve no pant rip curl ebomb 1.5/2mm, not sure... but anyways i thought it was a large or medium but when i tried it on, it had like rolls and it didn't seem so straight and smooth because it crease out, i'm 155-160lbs... and its an x large
is this gonna even keep me warmer? thanks
Old     (boyet)      Join Date: Apr 2007       04-13-2007, 1:03 PM Reply
it should be tight enough to follow the curves of ur body no creases or it wont trap heat inside
Old     (proho)      Join Date: Aug 2005       04-13-2007, 2:00 PM Reply
a wetsuit needs to be skin tight. sometimes the arms or legs may be a little long causing it to bunch a bit, but this is fine.
Old     (bftskir)      Join Date: Jan 2004       04-13-2007, 2:03 PM Reply
you should be in a small or medium.
a too large wetsuit will let too much water wash in and out and you will never be warmer in it.
buy one that fits tight/snug or as the germans say gooodentight
Old     (jpk)      Join Date: Sep 2005       04-13-2007, 2:13 PM Reply
At least it is probably easy to put on. The tight, heavy neo tops are a pita to put on and take off. But X-Large is probably too big. I'm the same weight as you and wear an M.
Old     (boyet)      Join Date: Apr 2007       04-13-2007, 2:24 PM Reply
isnt that wat i just said?
Old     (bbking)      Join Date: Dec 2006       04-13-2007, 8:43 PM Reply
shoot... my dads gonna be pissed about buying a new one cuz rip curl sucks at their service...
i'll maybe brave the cold or i dunno, thanks though
