Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 01, 2004
Old    likeknives            04-26-2004, 11:40 AM Reply
when u approach the wake for a trick, do u point the tip towards the wake or the boat? or in between? excuse my retardedness... im just beginning
Old     (jarrod)      Join Date: May 2003       04-26-2004, 11:43 AM Reply
straight into the wake. Check out the Detention or Higher Learning instructional videos. They wqill help to explain a lot.
Old     (canaday)      Join Date: Dec 2002 Location: Hawthorne       04-26-2004, 1:40 PM Reply
Don't apologize for asking questions. Just post in the trick tips section. Everyone here started from where you are at too.
Old     (pittsy)      Join Date: Apr 2004       04-26-2004, 6:26 PM Reply
you should try and cut in at about a 45 degree angle to the wake.
hope this helps
Old    sk8joe01            04-26-2004, 7:33 PM Reply
uhh, well to state the obvious: when you get out on the water it will be prety clear. its one of those things you don't really think about that much, it just depends on how hard you are cutting into the wake
