Old     (mikea)      Join Date: Mar 2005       11-21-2020, 2:36 AM Reply
for a winter/spring project....
I am thinking that the speakers that came with my 06' v ride need to be replaced.
Does anyone know what the model number is?
Not sure if I want the same speaker. BUT i do want the same size and mounting screw pattern.
Also I have read on here..
most people post that you have to remove the windshield, some people post that you don't
Bonus info:
2006 malibu Vride with factory speaker on the dash
I do have a ratcheting screw driver (about 1-1/4" from point to top of ratchet)
Old     (chpthril)      Join Date: Oct 2007       11-24-2020, 11:51 AM Reply
The model should be on a sticker on the magnet. I think it was a KS model. However, that model has LONG since retired, so you likely wont be going back with the same model. The new model would actually be a true marine speaker, the KM654. Add an "L" to the end and you get LEDs.
Should be a typical 6.5" with a 5" cutout.
Remove the windshield. Much easier then it looks. Easy with a helper. Much faster then turning out screws 1/4 turn at a time, only to find you need to do some trim work for the added depth of the new speakers.
