Old     (steves1967)      Join Date: Oct 2006       07-29-2019, 3:07 PM Reply
I have a Calabria Pro V and I have to fold the tower down when I put it away. The way the tower speaker tubing runs through the tubing, I have a plug on the port side of the boat, about 24" above the boat. The plug is starting to fall apart and needs to be replaced. Anybody know of a good plug that would work? I was thinking of using the GM style weather-pack connectors.
Old     (RPM_DLX)      Join Date: Jul 2010       07-29-2019, 6:32 PM Reply
If I am understanding the question right, look at the neutrik speakon stx series plug and receptacles. Depending on how many wires and if you want solder on connection would depend on the part number.
Old     (steves1967)      Join Date: Oct 2006       07-30-2019, 4:04 AM Reply
Guess I should have posted a couple pics. The blue circle is where the wire comes from the boat and goes to the tower. The red circle is the plug that I have to undo everytime I fold the tower. That plug is starting to fail.
Old     (RPM_DLX)      Join Date: Jul 2010       07-30-2019, 8:40 AM Reply
Take a look a the Neutrik Connectors. That's what I used and most kits use. Worked great. Look to see if you have 4 or 8 conductors. You will need to disassemble those. The ones you have now look like the Neitrik connector.
https://www.neutrik.com/en/neutrik/p...ors/stx-series
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-30-2019, 9:31 AM Reply
agree neutrik connex are your best bet..
in other news, what nimrod wired that tower? could've used the back legs and had no need for a connector.
Old     (steves1967)      Join Date: Oct 2006       07-30-2019, 3:46 PM Reply
The wiring was done at the factory. I'll check out those connectors
