Old     (humboldt9)      Join Date: Jun 2004       06-23-2020, 10:33 AM Reply
2002 Sanger V210 blower stopped working last time out. When flipping the switch at the dash the red light does not illuminate so I'm thinking the fuse went bad. All other switches at the dash are working properly. Boat is stored out at the river right now, anyone know if the fuse is located up underneath the dash and what type of fuse is the replacement? FWIW I swapped out the old blower for a new one.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-24-2020, 6:58 AM Reply
post pics of your dash. on my '06 there's a row of fuses under the steering wheel.
Old     (humboldt9)      Join Date: Jun 2004       06-24-2020, 7:21 AM Reply
Boats out at the river, but pretty sure it's the same dash as yours. So fuses under the dash? Any idea what fuse to swap with? Thanks for the reply...
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-24-2020, 8:10 AM Reply
look like white buttons? typically they pop out when blown. and they're the cylindrical fuses with metal caps on each end. usually right below the relevant switch. push on it, may free the spring inside.
could have a loose wire back there on the blower as well. On an different boat I kept in public storage, had a bird build a nest in the blower over the winter. so maybe check the blower itself.
Old     (humboldt9)      Join Date: Jun 2004       06-24-2020, 8:47 AM Reply
yep cool I replaced the blower already... i figure it's something behind the dash either the fuse or a loose wire. Yep my dash has the white buttons I'll try and figure it out. thanks for the help...
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-24-2020, 8:56 AM Reply
NP, good luck with it.
