Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (x2momma)      Join Date: Jun 2005       08-09-2008, 11:13 AM Reply
Hello all...
We have a 2005 MC X2 with stock ballast.
Changed out the impellers at the beginning of the season. They worked ok for a bit. Now we have 1 tank that will work fine, 1 tank that will fill but not empty and 1 tank that can't decide if it will work either way from one day to the next.
We have taken most everything apart to figure out what is wrong. We think the problem is a blockage somewhere in the lines from the pumps to the tanks/sack. That is where we need the help. How the heck do you get out the blockage?? Could the problem be something else?
We do have a good dealer that is 45 min. away from us. We would prefer to fix this problem ourselves... better to take the money we would spend at the dealer to fix this and put it in the gas tank instead.
Any help will be appreciated.
Thank you.
Old     (x2momma)      Join Date: Jun 2005       08-10-2008, 5:46 PM Reply
Anyone able to help?
Old     (crushing76)      Join Date: Feb 2007       08-11-2008, 10:13 AM Reply
if you are sure it's blockage in one of the tubes, if there is a way to get a power washer nozzle in it, that would most certainly break it loose and blow it out.
Old     (polarbill)      Join Date: Jun 2003       08-11-2008, 10:55 AM Reply
Nic, when you replaced the impellers did you use the black or yellow ones. The yellow ones are the ones you want. They seem to prime better and not get stuck.
Old     (x2momma)      Join Date: Jun 2005       08-11-2008, 11:18 AM Reply
C.R. - Had not thought of using a power washer. Good idea, thank you.
Brett - We used the yellow ones.
