Old     (CALIV210)      Join Date: Jun 2015       04-02-2018, 12:51 PM Reply
I think I asked these questions already but I cant seem to find my previous posts like on other forums . Im sorry if I'm repeating my posts.
Im getting ready to change the impeller,oil and filter . I was wondering if you guys knew the Napa or Wix oil filter number and if any of you with higher hours are switching to a thicker oil or sticking with the OEM specs ? I recall Kendall oil being highly recommended at 1 time does this still hold true ?
Old     (ottog1979)      Join Date: Apr 2007       04-02-2018, 2:24 PM Reply
I buy OEM Mercruiser Quicksilver parts, stocked in-store, at WalMart. In the auto parts area they have the recommended 25W40 oil, recommended Quicksliver OEM oil filter & fuel filter/water separator. I order impeller on line. My V210 has 1050 hours on it and I have no reason not to stick with the OEM recommended oil.
Old     (CALIV210)      Join Date: Jun 2015       04-03-2018, 5:17 AM Reply
I never even thought to try Walmart . Thanks for the info . I wasn't sure about the oil but I know these rollor motors want a lot of zinc to keep them lubed up good . Do you happen to have a filter part number ?
Old     (ottog1979)      Join Date: Apr 2007       04-03-2018, 9:36 AM Reply
Don't have the part numbers handy. Google. Also check the numbers on the filter you're removing. That said, there's only one inboard 4-stroke Quicksilver oil filter in stock at WalMart and it's the right one. There's only one fuel filter there too. Recommended Quicksilver 25W40 oil as well.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-03-2018, 9:50 AM Reply
me neither!
Old     (CALIV210)      Join Date: Jun 2015       04-03-2018, 10:16 AM Reply
Ok so I got everything coming except I went with Valvoline VR1 Racing oil with a lot of zinc .
I got a new impeller with housing this time too the last time I changed the impeller the housing was getting rough .
THANK YOU
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-03-2018, 10:24 AM Reply
I wish someone would figure out how to catalog and identify Merc parts, cause it's a PITA search for the right parts every time
Old     (ottog1979)      Join Date: Apr 2007       04-03-2018, 10:28 AM Reply
Don't forget the impeller
Mercruiser #47-862232A2
Old     (shaunnelson13)      Join Date: Jan 2016       04-03-2018, 11:45 AM Reply
http://www.wakeworld.com/forum/showthread.php?t=806137
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-03-2018, 12:02 PM Reply
Originally Posted by shaunnelson13 View Post
remembered finding them, just couldn't remember where to start. should probably save these...
Old     (CALIV210)      Join Date: Jun 2015       04-05-2018, 2:31 PM Reply
I saved that link this time !!! Thanks .
What about the impeller ? Anyone know the number on it ? I have a complete kit with housing but I dont know if its for this boat or not . I wish I would have wrote on it what it fits .
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-05-2018, 2:45 PM Reply
http://www.skidim.com/DOUBLE-FLAT-SH...nfo/BBB136327/
same one Andy had above
DOUBLE FLAT SHAFT IMPELLER MERCRUISER
AROUND 2002 UP MERCRUISER
#47-862232A2, Black Scorpion S/N OM391600 and up, S/N OW690000 and up. MX 6.2L S/N OM317000 and up. 5.7 MPI SKI S/N 1A090000 and up. New style pump that has the 2 blue water drain petcocks.
Old     (CALIV210)      Join Date: Jun 2015       04-06-2018, 7:09 AM Reply
THANKS DUDES !!!
My boats a 1998 . I'm 95 percent sure I have the right kit. lol ( you never know) The one I have is a Sierra kit and according to Sierras website it has to be the right one . My Pump doesn't have drain cocks on it either If I'm not mistaken .
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-06-2018, 11:34 AM Reply
one I linked is for 2002 +, I think....
Old     (CALIV210)      Join Date: Jun 2015       04-07-2018, 7:00 AM Reply
You sir are correct . 2002 was right when they changed over according to the research I have done.
Old     (CALIV210)      Join Date: Jun 2015       05-02-2018, 1:54 PM Reply
Holy crap I've been busy . Got my boat serviced thanks for all the help here guys . I got my buddys Chapparal Deck Boat dialed in an ready impellor and the rest of the service cha cha . Now to finish his trailer brakes . Then next weekend I'm doing another Sanger this time my cousins V215.
