Old     (brycejb328)      Join Date: Aug 2009       05-08-2015, 6:57 AM Reply
Hey everyone, the specs on fultons website for the F2 are kinda vague, does anyone know if the fulton F2 will go lower than my current jack?
Old     (Cabledog)      Join Date: Dec 2013       05-08-2015, 10:23 AM Reply
if you get the one with the foot instead of the wheels it might but my F2 doesn't go as low as the old one that is similar to yours. I'm at work so I can't check it with a tape at the moment.
Old     (jonblarc7)      Join Date: Jul 2006       05-08-2015, 11:09 AM Reply
You could always use a floor jack to get it lower.
Old     (volzalum)      Join Date: May 2009       05-08-2015, 11:48 AM Reply
The F2 has an 8 inch wheel plus the anchoring stuff so 10 inches is about as low as it will go.
Old     (ian_ashton)      Join Date: Jul 2008       05-09-2015, 4:58 PM Reply
The mounting point is adjustable though, so that could buy some more drop.
Old     (brycejb328)      Join Date: Aug 2009       05-10-2015, 6:44 AM Reply
thanks for the feedback. ended up riding with a buddy yesterday who has the F2 on his rig and it looks like the F2 is 3 inches higher when completely lowered. I need to be at least an inch or so lower than my current setup...
Old     (cwb4me)      Join Date: Apr 2010       05-10-2015, 9:54 AM Reply
If you need the tongue lower you could move the mounting point closer to the axle. If you're trying to create garage door clearance you can lower tire pressure to gain the inch.
Old     (cwb4me)      Join Date: Apr 2010       05-10-2015, 9:57 AM Reply
Another option is to make a extender plate and use counter sunk screws on the trailer side to mount the jack back flush.
Old     (cwb4me)      Join Date: Apr 2010       05-10-2015, 9:58 AM Reply
Or you could go to Northern and get a smaller diameter wheel.
Old     (kenv)      Join Date: May 2002       05-10-2015, 5:28 PM Reply
I had a problem with my F2 when i got my trailer last month. Solved it by doing what Ian mentioned above. Took it off the trailer, slid it down to a lower point and gained three or 4 inches in the swing. I almost ordered the one with the foot but i was able to keep my wheel !!! Yes !!!! Picture was before I adjusted the shank on the mount. That backing will slide all the way down to the black ring you see below the little square sticker. I can post a pic this week with it in the lower position and measure it for you if you want to see the number?
