I have a 2006 malibu wakesetter with the 383 hammerhead engine. Over the past year we have started having a problem when trying to get on plain. It doesnt happen all the time but every now and then when we go to pull or just get the boat up n go it will get to around 25, start popping and we have to back off the throttle. Sometimes it will let us back off to around 20 and it will run but you can hear it sounding like its getting the fuel in spirts. A trick we have done in the past to fix it is take the fuel filter off under the back seat, blow out any gas in it and then put it back on and it would be good for a hour or so but this summer its gotten worse. We have replaced the filter under the seat, replaced the fuel regulator but still, same issue. Does anyone know what is causing this? Our next step is the fuel pump but before we spend 500 dollars we want to make sure that is what is causing it. Any help would be great, thanks!
