Old     (jmuthafnp)      Join Date: Feb 2006       07-02-2012, 6:04 AM Reply
Looking at my VDIG, the display for the starboard ballast has disappeared from the screen, even though ir still dumps and fills. I would assume that this has some sort of sensor on it. Anyone overly familiar with this issue? I have tried resetting everything and still doesn't show up.
Thanks.
Old     (boarditup)      Join Date: Jan 2004       07-02-2012, 7:19 AM Reply
Likely scum on the sensor, if you leave them full. I had this once and now fill up the ballast with a couple gallons of strong bleach, a touch of dish soap, and tap water at fall layup. I drive the boat on the trailer to the gas station to top off with fuel, and then pump out and add a couple gallons of RV anti-freeze. No problems since. Just have a small tube connected to a funnel and stick in the overflow. Do this outside of the boat and be patient. It is easier on a step ladder so you don't have to hold it higher than shoulder level for so long. It takes a while - be patient.
