Old     (jordanh)      Join Date: Feb 2013       03-19-2014, 4:36 PM Reply
Ive been going over my ballast ideas in my head for the last couple days now. I decided im going to integrate some and stick with manually filling others.
Do you guys have any pointers on using the attwood 1200 tsunami pumps? the way the previous owner of the boat had it set up was that the pump was submerged over the side of the boat for filling. so if i plugged it in after it was submerged it primed just fine. then he had it so you flip the pump around and put the pump on the bag above the waterline to drain it. this i had issues with.
Would it be better if I made a quick disconnect hose to switch the pump fittings around when draining/filling so the pump was always submerged in the lake?
Old     (chpthril)      Join Date: Oct 2007       03-19-2014, 4:45 PM Reply
To drain, you need to push the pump down into the sac a little and it will prime up. An aerator pump, like the T1200 HAS to be connected to the water source, so it will not drain the sac if its in the lake.
Old     (jordanh)      Join Date: Feb 2013       03-19-2014, 5:04 PM Reply
Alright, so the way I have been flipping the pump for draining and filling is correct. I will have to give it a try to push it down. Before I use to just grap the end of the hose and suck on it to get it to prime
Sent from my iphone
Old     (Bumpass1)      Join Date: Oct 2010       03-19-2014, 5:13 PM Reply
Check with the guys with Wakemakers.com. They will give you all the info you could ever ask for. They will know the best way to set things up the way you want to
Old     (simplej)      Join Date: Sep 2011       03-19-2014, 5:23 PM Reply
Push down on pump. Plug into outle. Suction begins. Release grip on pump. Allow to suck dry.
Old     (spencerwm)      Join Date: Feb 2009       03-20-2014, 9:09 AM Reply
http://www.wakemakers.com/resources/...ate-turbo-pump
