Old     (sidekicknicholas)      Join Date: Mar 2007       12-10-2014, 2:25 PM Reply
My uncle is retired, has lots of tools, and is an evil genius ....
Test fits
Custom Crank -
Very important welds -
Still more simple than a German car
Headers or Medusa's hair?
Old     (Greeko)      Join Date: May 2013       12-10-2014, 2:34 PM Reply
holy F, now thats a friggen engine!!!
Old     (grant_west)      Join Date: Jun 2005       12-10-2014, 2:57 PM Reply
OMG: that's amazing. What's the estamate on HP and what's it going in?
Old     (seth)      Join Date: Sep 2002       12-10-2014, 3:16 PM Reply
Drop it in the supersport!
Old     (onlyinboards)      Join Date: Oct 2014       12-10-2014, 3:23 PM Reply
what is it going in????
Old     (hp_inc)      Join Date: Jul 2007       12-10-2014, 3:48 PM Reply
Holy s@$t that is alot of engineering. Awesome work! Are those 2JZ's? I had a friend that played around with those motors. Never to your uncles extent, but he got close to 900 HP out of his and that was just one. ;-)
Old     (durty_curt)      Join Date: Apr 2008       12-10-2014, 5:58 PM Reply
That sucker will snap chicks necks and prop shafts in no time!
Old     (superair502)      Join Date: Mar 2010       12-10-2014, 6:15 PM Reply
Those are rb Nissan engines right?
Old     (aricsx15)      Join Date: Jan 2014       12-11-2014, 8:31 AM Reply
If they're out of a supra, they are 2JZGTE motors
Old     (jonblarc7)      Join Date: Jul 2006       12-11-2014, 8:56 AM Reply
WOW
But what is it going in???????????????????????????????????????????????? ???????
Old     (sidekicknicholas)      Join Date: Mar 2007       12-11-2014, 10:47 AM Reply
TBD .... at this point he thinks a custom tube frame car and he'll probably make it mid-range because of the weight.
Old     (corerider)      Join Date: May 2008       12-11-2014, 11:11 AM Reply
I think those are 1JZ engines, but could be wrong. Cool project and LOTS of machine work! Looks as if he flipped one of the heads around, created a custom valve train for it, and now the exhaust exits the top of the engine similar to the newer Ford Turbo Diesels.
Can't wait for more progress pics!
Old     (sidekicknicholas)      Join Date: Mar 2007       12-11-2014, 11:28 AM Reply
Correct, they are the 2.5l engines.
Correct again, he started with them opposite but flipped one to keep the common ports to the center
Old     (baitkiller)      Join Date: Jan 2010       12-11-2014, 2:43 PM Reply
Incorrect:
Look again, not headers but induction pipes that lead to a collector that, without question will be bolted to an aftercooler.
The hot side of the turbos pretty much bolt right onto the heads.
Bad ass no doubt.
Old     (corerider)      Join Date: May 2008       12-11-2014, 4:31 PM Reply
Originally Posted by baitkiller View Post
Incorrect:
Bad ass no doubt.
Look again closely... Notice in the first pic the turbos are outboard of the heads. Now look at the heads and notice the left head has a smooth machined surface. That is the back of the head, no camshaft half moon cutouts. The right side you're looking at the front... Notice the non-machined surface and half moon cutouts for the camshafts.
Now on this pic looking at the front of the engine again you will notice the left head is not machined, but the right head is... they were swapped making the intake ports be on bottom now while the exhaust in on top. To get the cam gears on the right head to the front of the engine he would have to machine new half moon cutouts along with other work I'm sure.
Also in the final pic there is no place for fuel rails or injectors. Not to mention a plenum style sheet metal intake would much easier and probably less time-consuming to build than that nest of snaking pipe. That is most definitely exhaust! Those thin pieces of sheet metal are probably just a flat surface to reference ending each pipe. I'm sure that is where a thick flange will be welded for the turbo/turbos to mount too.
You can't expect him to use stock turbos after all the custom machine work and fabrication that has gone into this thing either. I imagine it will be a big single or small twin turbo setup.
Old     (baitkiller)      Join Date: Jan 2010       12-12-2014, 4:22 AM Reply
wrong again, rats, well it's happened to me before may happen again
Old     (snyder)      Join Date: Feb 2006       12-12-2014, 7:08 AM Reply
I hope he puts it in that wooden car in the 2nd to last pic.
Hey Grant, I bet his toolbox is messy... lol
Old     (timmyb)      Join Date: Apr 2007       12-12-2014, 10:02 AM Reply
That is NUTS! Awesome on so many levels! Of course we will need a sound clip when it's fired up and running.
Old     (sidekicknicholas)      Join Date: Mar 2007       01-22-2015, 5:44 PM Reply
Next update:
* Mated the engine to the transaxel and started to process how to package everything
* PVC is a rough frame of how the frame will ultimately look, getting an idea for space and where things will route
* Cardboard box around the transaxel is half of a fuel tank that is planned
* New linkage mechanism so the 6-speed can be shifted from up front with a pair of Morse push-pull cable(s).
* Engine will be twin turbo'd with two - Garrett GTX 3076's with .85 AR turbines
.... the car will be twin turbo, not quad.
Old     (sidekicknicholas)      Join Date: Mar 2007       04-06-2015, 7:12 AM Reply
Frame is coming together and it will only be a twin turbo now.
Old     (sidekicknicholas)      Join Date: Mar 2007       04-06-2015, 7:14 AM Reply
Old     (timmyb)      Join Date: Apr 2007       04-06-2015, 8:13 AM Reply
Very cool!
Old     (jonblarc7)      Join Date: Jul 2006       04-06-2015, 8:38 AM Reply
Very very cool!!!!!!!!!!!
Old     (brycejb328)      Join Date: Aug 2009       04-09-2015, 9:21 AM Reply
Has the engine been started yet, video please, if it has. That thing is beyond wild.
Old     (sidekicknicholas)      Join Date: Mar 2007       04-09-2015, 10:00 AM Reply
Not yet.
He said he only wants it to be him and his other good good buddy in the room, in-case they need to talk/move quick rather than a zoo of people. I'm pretty pumped to see it run though.... its going to be insane.
Old     (viking)      Join Date: Sep 2009       04-09-2015, 10:09 AM Reply
Damn that is sick!
Old     (Rich_Bruening)      Join Date: Sep 2010       04-09-2015, 4:59 PM Reply
bummer she'll only be a twin... but still... those straight 6's are crazy responsive. That thing will turn heads and snap necks for sure...
Old     (Rich_Bruening)      Join Date: Sep 2010       09-04-2018, 8:32 PM Reply
any updates to this crazy project???
Old     (Koolaid)      Join Date: Feb 2018       09-05-2018, 1:30 PM Reply
https://www.engineswapdepot.com/?p=25092
Old     (denverd1)      Join Date: May 2004 Location: Tyler       09-05-2018, 1:41 PM Reply
damn that sounds good!!
Old     (dougr)      Join Date: Dec 2009       09-06-2018, 5:15 PM Reply
he is a wonderful man, don't know him, but love him
