Old     (rolltidehack)      Join Date: Jul 2014       08-03-2014, 4:50 PM Reply
My boat is in our dock and finding that water is leaching in from somewhere. I have checked the exhaust and plug and both are sealed. Thought on what else to look at? Do shaft seals tend to leak a bit?
Old     (TN_Jeeper)      Join Date: Jun 2014       08-03-2014, 6:06 PM Reply
Check the shaft and the water pump. If the water pump is going bad sometimes they will leak around the shaft that runs to the fly wheel.
Old     (phathom)      Join Date: Jun 2013       08-03-2014, 9:59 PM Reply
Check the rudder and the drive shaft packing rope.
How much water are you leaking in?
Old     (rolltidehack)      Join Date: Jul 2014       08-04-2014, 1:51 PM Reply
Over night it was about 2ish inches in the rear. I'll check both. I found that the pump to fill the ballast leaks when I turn it on. Shafts seals where just done about 4 months ago.
Old     (rolltidehack)      Join Date: Jul 2014       08-04-2014, 7:25 PM Reply
Hey I checked the stuff and it all seems tight. One thing I notice, it only leaks in the same amount and then seems to stop? Confused on what else it could be.
Old     (rolltidehack)      Join Date: Jul 2014       08-04-2014, 7:26 PM Reply
Also the pump is auto but I have to switch the wires cause it's on auto but the red led light stays on and will drain the battery, from what I was told
Old     (steves1967)      Join Date: Oct 2006       08-04-2014, 8:55 PM Reply
My shaft seals are leaking on my boat... that could definitely be your source.
