Old     (repo)      Join Date: Feb 2010       02-18-2011, 7:28 PM Reply
Whats involved in changing out the prop shaft seal in a 06 Sanger V215. I think mine has started to leak. Will be pulling it up on the trailer to check it out tomorrow.
Old     (wake_upppp)      Join Date: Nov 2003       02-18-2011, 8:23 PM Reply
They are supposed to leak some. 10 drops a minute or something like that. You can adjust them as well. If you don't have the dripless packing, it's normal.
Old     (repo)      Join Date: Feb 2010       02-18-2011, 8:43 PM Reply
Its leaking a little more than 10 drops a minute.
Old     (wake_upppp)      Join Date: Nov 2003       02-18-2011, 8:44 PM Reply
Try to adjust it. Maybe it's 10 drops every 30 seconds, I for get now. Something like that.
Old     (rallyart)      Join Date: Nov 2006       02-19-2011, 12:11 AM Reply
Ian, mine is an '06 with over 300 hours and I adjusted mine for the first time this summer. It makes a big difference. I had it a bit too tight and had to loosen it a smidge to get enough drip. I wanted to in '09 but I did not have the wrenches. The nut was a 2" and the lock nut was 1-7/8". Or at least those are the wrenches I used. You could but one combination open end wrench and cut the middle out of it. It's pretty quick to do.
I think 10 drips per minute is not a big deal. Mine was maybe 35 before I tightened it. It might have been 5/min. when I was done.
Old     (dave27)      Join Date: May 2005       02-22-2011, 10:54 AM Reply
I just adjusted mine for the first time at 490 hours. Mine looked like a 5 year old boy peeing off the side of the boat. I cut off the safety wiring, broke free the jam nut, turned the adjusting nut one full turn. Then tightened it all up. Now it is sweet. I put back the safety wiring but I am not really sure I need it.
My Sanger dealer/shop told me 10 drops per minute.
Art did you remove/replace the safety wire?
Old     (rallyart)      Join Date: Nov 2006       02-22-2011, 12:22 PM Reply
Never put it back on
