Old     (scott)      Join Date: Feb 2010       06-29-2020, 7:15 AM Reply
What is everyone doing with the pumps in your V237's after you take out the stock hard tank and install the Fat Sack? The pumps are kinda in the way of the fat sack and the sack will lay on the pumps and the plumbing coming into the boat.
Scott
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-30-2020, 5:55 AM Reply
sacks laying on the pump isn't a big deal. probably need to protect the lines tho. they're hard lines right?
Old     (mpleasance)      Join Date: Feb 2009       06-30-2020, 6:27 AM Reply
I put an elbow on the fill line right after the shut-off value to turn the fill pump parallel to back of the locker and then sort of tuck the drain pump under it. My drain pump has a very short piece of hose to a right-angle quick connect. That made the pumps take up a little "floor space" as possible. The drain fitting on my wakemakers bags is right at the bottom on the end, so the bottom of the bag sits in front of the pumps. However, when it fills, the end of the bag covers the pumps. I used a combination of tennis balls and pool noddles on any sharp edges in the locker and so far haven't had any problems in three years since doing the upgrade.
