Old     (djl)      Join Date: Mar 2013       06-11-2015, 12:12 PM Reply
I am looking at making my first V-Drive purchase and I am fairly new to the world of wake surfing. I am currently considering 3 boats and was wondering if anyone has had any experiences with them. Which of the 3 have the best out of the box surf wake?
Any advice would be appreciated.
The 3 boats are:
2008 Tige RZ2
2008 MB Sports B52V 22'
2012 MB Sports B52V WideBody 21'
Old     (cain0725)      Join Date: May 2012       06-11-2015, 4:22 PM Reply
I've had nautique and MC,, so don't know really, i have heard good things about both. In arkansas axis has really took off. MB dealer also but i don't see many on the water. I think fit and finish is better on the MB though
Old     (Bam6961)      Join Date: Apr 2011       06-11-2015, 7:19 PM Reply
2012 MB hull out of the box will be miles a head of the 2008 MB. the 2012 hull is v shaped (better for surfing) and the factory ballast is not only more but more convenient with the flood gates.
Old     (Bam6961)      Join Date: Apr 2011       06-11-2015, 7:31 PM Reply
also ballast in the 2012 MB is 1,800lbs and 2008 tige had an optional 900lbs. Both will probably need more weight to get a nice wave but out of the box the mb will be better due to the extra weight.
Old     (LouZahr)      Join Date: Aug 2011       06-11-2015, 7:46 PM Reply
I use to own an 08 RZ2. Had about 1100 pounds in each rear corner and that boat would throw a big, fun surf wave.
Old     (djl)      Join Date: Mar 2013       06-11-2015, 8:57 PM Reply
Thanks for the response.
I guess the 2012 sold so it's down to the 2008's.
The B52V is actually 21'6 I wonder if that will be a big enough boat to give me a good wake. It does have 1800 pounds of factory ballast.
Old     (retoxtony)      Join Date: Apr 2012       06-11-2015, 9:44 PM Reply
I have a 07 RZ2, not sure how it compares to the 08 MB but i can say it does put up a nice surf wake. The Tige factory ballast system is small and you'll really want to pull most of it and add your own sacs to make it surf better.
Old     (westsidarider)      Join Date: Feb 2003       06-11-2015, 9:57 PM Reply
An 08' b52 is my primary wake maker(don't currently own). Probably one of the best all around wake machines of the time before major focus on surfing came into play. We currently run the following in weight:
Wakeboard
Full factory ballast(2 hard tanks on port and starboard rear to mid ship)
~900 lbs lead mid ship under seats
400 lb sack on floor mid ship, all the way to the the back
750 lb sack in the bow along with about 150 lbs of lead under the seats in bow
Surf
Take the same weight as above , empty one side of factory tanks, move all mid ship lead to one side and drain sack in bow to ~3/4 capacity.
These setups work well for up to 4 people. Any more people and your taking on a ton of water while surfing or taking way too long to get on plane while boarding.
Old     (westsidarider)      Join Date: Feb 2003       06-11-2015, 10:06 PM Reply
Old     (djl)      Join Date: Mar 2013       06-11-2015, 10:09 PM Reply
Thanks a lot guys!
Jason,
Is that a 23' or a 21'6 B52? I heard the length makes a difference. Can anyone comment on this?
Old     (westsidarider)      Join Date: Feb 2003       06-11-2015, 10:42 PM Reply
That's the 21'6". Haven't been behind a 23'
Old     (westsidarider)      Join Date: Feb 2003       06-11-2015, 10:44 PM Reply
First pic doesn't show the wave but I threw it in there to show that it's good enough to party wave it 🍻🌊 Not a ton of room to do much with 2 riders but you can cruise no problem
Old     (shawndoggy)      Join Date: Nov 2009       06-12-2015, 9:03 AM Reply
if you can stretch to $45K.... http://www.mbboatowners.com/index.ph...an-card-45000/
Old     (djl)      Join Date: Mar 2013       06-12-2015, 9:34 AM Reply
Originally Posted by shawndoggy View Post
I live in Canada but if I was near Texas, I would definitely be putting in an offer! Thanks
Old     (djl)      Join Date: Mar 2013       06-13-2015, 6:02 PM Reply
I ended up buying the 2008 B52. Thanks to all who posted
Old     (retoxtony)      Join Date: Apr 2012       06-13-2015, 9:16 PM Reply
Pics?
Old     (djl)      Join Date: Mar 2013       06-15-2015, 3:21 PM Reply
All I have for now until I take delivery this weekend
Old     (djl)      Join Date: Mar 2013       06-15-2015, 3:22 PM Reply
