03-16-2015, 10:02 AM
I've been looking on Wake World for quite some time and have seen some quality installations and figured we could share some of ours. We are currently working on a 2014 Centurion Enzo which is getting the works. A Wet Sounds WS420BT, 2-pairs of Wet Sounds Rev10's, Wet Sounds XS-650 interior speakers, 2 Wet Sounds XXX subwoofers and all Arc Audio amps to compliment the system. We are currently working on a front facial panel for the amps in the storage area and the subwoofers that are under the drivers dash area. I will post up pics as soon as I can of that. We will also be changing out all the existing interior/accent blue LED's in the boat for red. Check out some in progress pics and let us know what you guys think.
03-16-2015, 2:58 PM
Looking good so far.
I've got the same boat in my shop right now too, getting almost identical equipement. We're using SD2's for the subs, and Syn4's for in-boats and towers though. This boat was built 3 years ago, but in for upgrades.
03-16-2015, 5:23 PM
In the planning stages for a 2015 FS44. Getting 2 pair rev-10, from current boat. They will be driven with a pair of SD-6, which will also drive the 3 pair of in-boats. This is an awesome setup. Sub is looking like JL W7 on a HD1200/1.
03-16-2015, 8:09 PM
You guys running your rev 10's at 80hz?
03-16-2015, 8:20 PM
Depends on the wattage driving it as well as if its a surf/party cove setup or is wake range projection the main focus.
03-16-2015, 8:27 PM
Wake range w/syn 4. And is there a better setting for chillin?
03-17-2015, 5:58 AM
Confused... I see a ks300.2, a ks300.4, and (i think) a ks2500.1. Where's the other amp for the Rev10s? Or are you powering two pair of Revs from a 300.2?
03-17-2015, 6:33 AM
300.2 and 300.4 are the same size. None of those amps are the same size. I am guessing they are running a 600.2 which is perfect for two pair.
03-17-2015, 6:46 AM
I agree with cowboy, looks like a 300.4 and 600.2 since I see only a single set of RCA inputs on the amp on the right.
03-17-2015, 6:57 AM
The install looks great very clean but I would think the XXX would need more power than 700 watts a piece.
03-17-2015, 8:15 AM
That's correct. We are running a 300.4 for interior speakers, 600.2 for the tower and a 2500.1 for the subwoofers. The KS2500.1 is a very under rated amplifier and is having no problem pushing the two XXX subwoofers. I'll be sure to post up pics of fitment and the trim panel for the subwoofers as soon as we can. Thanks for the compliments guys.
03-17-2015, 8:24 AM
ha ha my bad I should know better since that's basically what I'm running too (1200.1, 600.2, 300.4).
03-30-2015, 9:32 AM
Here's a follow up on the amp rack and sub woofer enclosure. We also built a raised floor next to the amp rack to allow for 4 batteries to be shoved as far back as possible and not be tilted at a crazy angle.
03-30-2015, 6:27 PM
amp rack looks nice but with your sub install there is no leg room for the driver.
03-30-2015, 7:39 PM
I don't like it
03-31-2015, 3:36 AM
Post pics of the Rev 10's on that new Maximus Tower when you get it done please!!!
Install looks good! I wouldn't give up my leg room though.
03-31-2015, 4:27 AM
like the amp area, but as with others, would not give up the legroom for that. looks real cramped.
03-31-2015, 2:35 PM
nice boat and install, don't really like that sub install, not only has zero leg room, but that white cup holder makes it look ugly, why wouldn't you mount the sub on the original panel under the helm?
03-31-2015, 3:29 PM
just noticed, the EQ, that's kinda funky also...
03-31-2015, 8:48 PM
There were tons of ideas that we were bouncing off the customer and he had to have 2 Wet Sounds XXX and wanted them both under the dash which made it a little cramped for leg room and he was totally fine with that. It was definitely tough to try and accommodate 2 12s, eq and retain the cup holder but mission accomplished per customers request. Thanks for the compliments on the amp rack.
03-31-2015, 8:52 PM
We don't have Rev10s on the maximus tower but I do have a shot of the icon8 which sit very nice.
04-01-2015, 4:12 AM
Thanks for the pics! Much cleaner than the factory Downfires. Plus Im sure more headroom
04-01-2015, 6:28 AM
Well, I guess the customer is NOT always right. Looks like you did the best you could given the circumstances.
That must be loud as hell.
