Old     (black_ops_09)      Join Date: May 2009       09-18-2010, 6:42 PM Reply
I have a 2009 Sanger 215 and noticed fuel consumption seems bad. Do the mercruisers have air filters if so where?
Old     (islander033)      Join Date: May 2008       09-18-2010, 7:45 PM Reply
They typically have flame arrestors that you can take off and wash.
What kind of consumption are you experiencing (weighted and/or unweighted)?
Old     (black_ops_09)      Join Date: May 2009       09-18-2010, 8:47 PM Reply
So the spark arestor is the so called "air filter"? Well I have about 300 extra lbs in boat not much crew is like 4. I didnt pay to much time on hours spent today or how many gallons I used but will watch thaton next outing, just seemed bad I usuelly make it til dusk today by 4 I was danger close.
Old     (rallyart)      Join Date: Nov 2006       09-18-2010, 11:08 PM Reply
If you have the Scorpion engine there is just the metal disks of the flame arrestor just before the throttle. Not much there that will affect fuel use. It's more likely the speeds you are driving although 300# will drop your economy, especially if you are starting and stopping a lot. Surfing, of course, kills your economy.
Over the long term changing the plugs matters but that's over a couple hundred hours.
Old     (sanddragon2004)      Join Date: Jul 2005       09-19-2010, 7:48 AM Reply
the metal screen above the carb or throttle body, they get dirty, ur boat will run like shiz. get some carb cleaner, or an airhose and clean that bad boy up. u would be suprised what a dif it will make.
Old     (black_ops_09)      Join Date: May 2009       09-19-2010, 12:50 PM Reply
Andy, are you talking about the oval shape steal screen infront of the engine?
Old     (camassanger)      Join Date: Oct 2009       12-19-2010, 2:26 PM Reply
Guys, How do you get the spark arrestor off the engine to give it a good cleaning? Disconnected one hose and a connector, but it wont seem to come loose. Hoping I dont have to remove the whole throttle body. Advice?
BTW, my spark arrestor is VERY dirty! The bottom was the worst (I was able to spin it around...)
Old     (camassanger)      Join Date: Oct 2009       12-19-2010, 3:17 PM Reply
Update, posted too quickly. Dah, there's a 7/16" nut in the center to easily remove the spark arrestor. Nice and clean now :-)
Old     (justintime)      Join Date: Mar 2009       12-21-2010, 7:51 PM Reply
should be cleaned every year or 100hrs
