Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 01, 2004
Old     (magicr)      Join Date: May 2004       07-01-2004, 10:18 AM Reply
Should there be a washer between prop nut and propeller on an inboard boat. Mine does not have one, should it?
Old     (boarditup)      Join Date: Jan 2004       07-01-2004, 11:41 AM Reply
No washer. Your shaft has a taper and the prop is troqued home on the taper. If you have one of the newer MasterCrafts, there is no keyway. It is splined. You will have a nylon-insert nut and a cotter pin to hold the prop on.
