Old     (ryin)      Join Date: May 2002       05-21-2013, 7:51 AM Reply
I am unsure which size I want to go with!
Old     (DQ)      Join Date: Feb 2013       05-21-2013, 8:04 AM Reply
8" minimum in my eyes and prefer Wet Sounds, depending on what kind of boarding you do, if you surf more I would run either the Icon8, or the REV8, or if you do more wakeboarding I would do the REV8's or the REV10's.
Old     (Alleykat)      Join Date: Jan 2013       05-21-2013, 8:05 AM Reply
8's for sure. Performance wise they are the way to go.
Old     (david_e_m)      Join Date: Jul 2008       05-21-2013, 8:35 AM Reply
Surface area rules in an open field environment and based on surface area one 8-inch speaker is nearly like having two 6.5-inch speakers. Plus, you will undoubtedly have more pod displacement with an 8-inch speaker and that determines the low frequency extension. So an 8-inch will be warmer and play deeper.
When it comes to midbass extension, a higher quantity of a smaller speaker will never compete with fewer of a larger speaker. This also makes a 10-inch tower speaker advantagous over an 8-inch speaker.
David
Earmark Marine
Old     (wakereviews)      Join Date: Sep 2006       05-21-2013, 8:38 AM Reply
Just a should out to David here, man you always have the best answers. Knowledgeable but not too technical that are easy to understand. You are an awesome member of this forum. Cheers.
Old     (ryin)      Join Date: May 2002       05-21-2013, 8:52 AM Reply
ok, I am sold on 8" lol
Old     (murphy_smith)      Join Date: Dec 2005       05-21-2013, 9:10 AM Reply
Why not a 10? "one pair will get it done"
