05-25-2017, 8:08 AM
Has anyone had any experience with ballast pumps other than Johnson or Jabsco? I found these on ebay and am wondering if they'd do the trick or simply burn up in a season. Would like to plumb in my rear sacs on my Sanger.
http://www.ebay.ca/itm/Ballast-Bag-R...%257Ciid%253A1
05-25-2017, 8:12 AM
First I've seen of them. Who's going to be the guinea pig?
05-25-2017, 8:16 AM
300 GPH is only 5 gallons per minute, so it is substantially slower than the other offerings which are 9-11 GPM, depending on who you believe.
A gallon weighs 8 pounds, so 5 GPM will fill a 400 pound bag in 10 minutes.
05-25-2017, 8:18 AM
They're less than half the GPH capacity as others.
Also, it's just a re-branded Harbor Freight pump for twice the price. https://www.harborfreight.com/110-hp...ump-63317.html
05-25-2017, 8:20 AM
Interesting. Good catch!
05-25-2017, 8:52 AM
speed (or lack of it) is the biggest issue I see
05-25-2017, 8:56 AM
Lemonade: Not sure where you are located but I saw this the other day.
https://vancouver.craigslist.ca/pml/bpo/6129547967.html
05-25-2017, 8:58 AM
^ good deal
05-25-2017, 9:17 AM
Wow. $200 for 4?!
05-25-2017, 9:48 AM
I bought one online recently from HF for $41.22 shipped including tax using the 20% discount coupons they publish every week. The ones in the stores here are 120V. You get the 12V ones online. As noted above it's pretty slow filing the sacs. I haven't tried using the reverse capability. You have to manually switch the leads. There is not reversing switch. No idea about how long they last. Haven't used it much.
05-25-2017, 10:15 AM
switching leads?? forget that
05-25-2017, 10:26 AM
You could easily wire it to a double pole switch to handle that
05-25-2017, 10:38 AM
I checked eBay. You can get one from Malaysia for $10.39. I might just order one.
http://www.ebay.com/itm/60-A-Drum-Sw...-/272273695849
05-25-2017, 10:52 AM
Why wouldn't you just hook it up to this and make it look nice.
https://www.wakemakers.com/supra-moo...st-switch.html
05-25-2017, 11:16 AM
If it looked nice, it would look out of place on my old boat. LOL
05-25-2017, 11:36 AM
Lol
05-25-2017, 1:30 PM
the HF ones aren't ignition protected either.
05-25-2017, 1:40 PM
thought it might be doable that way.
still don't like the pump...
05-25-2017, 2:19 PM
Wow. $200 for 4?!
Yep! .....and that's Canadian so with the exchange the way it is right now that's like $ 10.00 USD.lol.
05-25-2017, 6:32 PM
My bags and pump are out in open air. So I don't need to worry about that.
05-25-2017, 7:21 PM
It's not that hard to set up two aerator pumps for each bag and they are SOOOOOO much cheaper
05-26-2017, 6:56 AM
agreed. I'm in the minority that prefers aerators.
05-26-2017, 10:15 AM
EXACTLY!!!
Yes, you have to actually think about what you're doing. But once setup right, aerators for the win all day long. Got 6 pumps in my boat. Tsunami 1200s can be had for $30.
05-26-2017, 10:19 AM
and faster!!
05-26-2017, 10:26 AM
and they don't burn out
and if they go bad, the cartridges are easy to replace
and they don't require 12AWG wiring
05-26-2017, 10:47 AM
The ONLY thing I don't like aerators is it can be tricky to set them up to fill while under way. But they are fast enough it doesn't really matter.
