the general rule or answer is the bigger the wake ,the faster you can go which means you can legnthen the rope to enable more hang time and bigger air.. other determining factors of rope legnth besides bigger air and hang time is how big and wide your wake is ,if its easy to get over but really big i go longer.. however if its easy to get over(narrow) and rampy/small ten go shorter then normal along with slower speeds... so a real wide wake both big or small wll cause most people to go shorter to make it easier to get over.. last factor is you can find the best place to put your rope legnth by looking for the sweet spot on your wake,generally where the wake is the cleanest and poppiest before it washes out or curls over..this is usually how a lot of riders decide where to put the rope out too... so basically in a nuttshell you have to figure out where the rope is best for you from boat to boat and situation to stiuation..
