07-16-2015, 6:36 AM
I am considering a boat that is a bit of a barn find. It is a 2006 X-Star that has been stored since its first season. It has under 20 hours on it so it is essentially a "new" used boat. It was shrink wrapped, winterized and stored in a shop the whole time. My concerns are mechanical. I know I would need to drain and flush fuel, change all fluids and get new batteries. My question is what else could I be getting myself into. I'm in California so freeze isn't an issue. It is an incredible boat, but I don't want to make any offers until I research it a bit. It isn't for sale anywhere so I'm not in a rush.
07-16-2015, 6:41 AM
Anything rubber is prone to dry-rot. hoses and belts should be inspected and I would anticipate that even if they look good now, they might go bad on you within the first 20 hours running it.
Water pump impeller should also be replaced.
If you're getting a good price on it and it's in great shape cosmetically, then I would go for it but with the understanding that you might be working some bugs out of it for the first season.
07-16-2015, 6:41 AM
rubber parts would be my next questionable items (impeller, hoses, etc.....)
07-16-2015, 7:01 AM
Not a 100% comparison but the dealer I bought my boat from got a Supra that had been sitting in a field for almost 4 years....they swapped the fluids, battery, etc and it fired right up...
07-16-2015, 7:16 AM
I had thought of the impeller but forgot to list it. I didn't really think about the hoses. I'm hoping for an easy exchange of fluids and impeller and an easy start. I just want to know the worst case scenarios so I don't get blinded by a "new" boat that could be anything but.
07-16-2015, 7:21 AM
Sounds like a good find.
Would love to see pictures.
07-16-2015, 7:22 AM
ballast hoses and impellers
bilge pump hose
gaskets should all be good. all should be cheap and easy. sounds like a nice find.
07-16-2015, 7:28 AM
Stored inside after shrink wrapping. It should be like new. The hoses will be great unless there is a lot of ozone near it. If the engine belt was loosened off it should be perfect, if not it should still be good. Change the fluids, lube everything, turn the engine over by hand a few turns, move all the cables all the way.
Break it in like a new boat and change the oil again after another 20-30 hours. Cool find. The story behind it might be sad, or interesting. When pricing, just remember it's a 2006 if you ever want to sell it so the low hours are not the key factor on price.
07-16-2015, 7:48 AM
I agree with Art. If it was wrapped, most of the soft parts will be fine. The ethanol fuel sitting in the fuel system can lead to problems, but you won't know that until you get it running. Perform all of the regular maintenance items, and you will most likely be good to go. Keep one thing in mind, though. When an engine has been sitting for that long, the oil will settle. So, before you fire it up for the first time, remove the spark plugs and pour about an ounce of oil in each cylinder. Then, crank the engine over by hand until you get tired. Do not skip this step!
07-16-2015, 7:55 AM
I would be concerned about the rubber hoses as well but, besides the impeller, the next thing I would worry about is fuel varnish in the fuel tank, fuel pump, fuel lines and injectors. At best you'll probably have to run some sort of fuel system cleaner and replace the fuel filter a few times. At worst you're going to need to replace all those parts, and possibly the fuel injectors too.
07-16-2015, 7:56 AM
Don't forget about the trailer. The tires are most likely need to be replaced and I would pump some grease in the bearing buddies right away.
07-16-2015, 7:57 AM
This is the WakeWorld version of Chasing Classic Cars! What a find. Do me a favor and let me know if you decide not to buy it . . . .
07-16-2015, 8:15 AM
bad fuel: locate the fuel filter and take it out. connect to another hose and run it out the drain plug. add air pressure to the fuel tank at the filler with a compressor. this will force all the fuel out of the tank. add some good gas, drive it around the block a few times and drain the gas again. install new filter and reconnect lines. you'll have to prime the fuel rail likely. Then you should be ready to crank
07-16-2015, 8:52 AM
Besides what everyone else has said, the only real worry I'd have is the cylinder walls. If they did not fog the engine during winterization then they may have a slight bit of surface rust. Just add a small amount of oil to each cylinder and turn over by hand before ever starting the engine like mentioned above. Before tearing off the shrink wrap (assuming its still there) I would inspect for holes that rodents could have made or gotten into. Having a critter living inside for a period of time could play havoc on wiring, interior, etc.
07-16-2015, 9:20 AM
Only other thing to watch that wasn't mentioned would be any of the engine seals drying out from sitting so long. If you got the boat for a good price all of the other issues mentioned above are minor to replace before firing it up.
07-16-2015, 10:33 AM
If they went to the trouble of shrink wrapping it the boat was probably winterized as well. Surely the owner will know if it was winterized. I would say if the price was $5000 or more below what it would be worth running go for it. Hoses, belts, impellers, etc are easy and cheap fixes but I would set my expectations that the first summer would be working out the kinks in it so you're not frustrated with it.
07-16-2015, 10:29 PM
If the boat was pickled basically brand new, I wouldn't worry about any of the rubber parts. They were new and have seen no sunlight, moisture etc.
What makes this rubber wear out more sitting under that shrink wrap than my boat sitting in my garage 350-360 days a year? .........Nothing! And nothing is dry rotted at going on 10 yrs old, nor was it going on 15 yrs on my old boat.
You will be getting a new boat if it's all what you say it is.
Need batteries, trailer tires before any big trips. Only issue may be if injectors get messed up with the old gas but even a good chance of no issue there, IMO.
Fwiw, the ballast intake hose on my 06 X2 was cracked and crispy a coup,e years ago. Replaced it after it broke trying disconnect it. Only hose on the boat with this issue and a buddy has the same year X and his is fine still afaik.
07-17-2015, 8:40 AM
I'd pop the distributor cap off just to verify no moisture got in (doubt it, but it's easy). The trailer should have oil on the bearings with sight caps, but do check the back side of the tires for signs of leakage. The fuel filter on this one is on the pump, they're known to fail. I'd look for crack on the alternator/water pump belt. From sitting the thermostat could be stuck, so if it goes above 160F once in the water shut down and head back in.
I also guarantee the impeller is toast.
Cheers,
DC
07-17-2015, 8:42 AM
Oh yeah also pop the panel under the driver front seat to verify the underdash wiring looks good.
Cheers,DC
07-17-2015, 9:50 AM
I'd worry about engine internals! An engine being stored should still have it's oil changed once a year to avoid the corrosiveness of acidification! And obviously it should've been cranked at those times to eliminate flat spots on bearings! Have a mechanic check it!
07-19-2015, 9:06 AM
Thanks guys. I appreciate all of the input. We will see if this is even possible. The owner hasn't given me a price yet. I'll keep you posted.
07-19-2015, 1:10 PM
John please pm me if you don't buy it I'm really interested
07-20-2015, 8:34 PM
And now some pics please!
07-21-2015, 4:19 AM
Make s:re it has an ecm and isn't actually an epic.....
