CC 210. The early years (2000-2002) had very little to no built-in ballast. Easy to take out either way. The gas tank was rather small so an expanded gas tank would be helpful. Gas weighs 6 lbs (vs water which weighs 8 lbs per gallon). You will also want weight in the bow to balance the boat. For this you will want to use a bunch of lead. Not for a bigger wake but for a balanced boat. Get up to 800 or 1000 lbs and you have a great wake boat.
