Old     (robertsjut)      Join Date: Jul 2009       07-14-2014, 7:21 PM Reply
It's a picture of the exit point of the shaft on a 2007 supreme v208.
Thanks
Sorry the picture is upside down.
Old     (robertsjut)      Join Date: Jul 2009       07-15-2014, 8:47 AM Reply
Should there be some type of plate/cover over this? It's my first v drive so just wondering. I was cleaning under the boat and noticed it.
Thanks guys.
Old     (jaws)      Join Date: May 2012       07-15-2014, 9:49 AM Reply
I wounder if that drive shaft was ever replaced
Old     (stuntmonkey)      Join Date: Feb 2009       07-15-2014, 1:43 PM Reply
Thanks guys.
No. But that driveshaft has been replaced. I'm betting the previous owner hit something and took a few chunks out of the hull that you can see.
Old     (bftskir)      Join Date: Jan 2004       07-15-2014, 7:11 PM Reply
Loose bolt lower left?
Old     (cadunkle)      Join Date: Jul 2009 Location: NJ       07-16-2014, 5:47 AM Reply
Looks normal to me. Bolts holding the log in may be loose as bftskir pointed out, check those and if loose I'd dap 5200 under the heads.. You can sand and either gel patch or smooth some 5200 over those small ships around the hole. Align it if it hasn't been done in a few years.
