Old     (Trever)      Join Date: Mar 2016       06-25-2016, 6:14 AM Reply
Hey guys- I am working on my tower today installing it. The tower came with 3x5 inch backer plates to spread the stress over a larger area. Do you think it would be necessary to add plywood of aluminum sheets.
Also, it tried putting the rope on the tow point on the tower. Usually when I use ropes I loop it on the tow point, then twist and put another loop, sort of like a rubber band. When I tried to do this on the tower, only one loop could fit. Should I try the method in this video?
https://m.youtube.com/watch?v=SjlpUbPnBm4
Thanks
-Trever
Old     (WheelerWake)      Join Date: Mar 2013       06-25-2016, 7:05 AM Reply
The method shown in that video is the most commonly used.
Old     (cadunkle)      Join Date: Jul 2009 Location: NJ       06-26-2016, 10:55 AM Reply
Whether additional backing is required depends on the thickness and strength of the attachment points to the cap. You can get away with a larger plate on the underside to spread the load but glassing in some backing is never a bad idea. Coosa or Starboard would be ideal, but wood will last just about forever since it's a dry area.
For the tow line, either way is fine depending on how big the loop is.
Old     (phillywakeboarder)      Join Date: Sep 2008       06-27-2016, 8:29 AM Reply
I think you'll be totally fine with the 3 x 5 plates. My tower was missing a plate on 1 of the 4 legs (it was just attached to fiberglass) and I didn't notice it for nearly a decade. I guess it came from the factory like that. The backing plates that came with the other ones are no larger than 3 x 5 and they've been fine since 1999. The one I made to replace the missing one is about 3 x 3 and has been fine for years.
