Old     (dogs)      Join Date: Oct 2009       09-09-2019, 5:58 AM Reply
I have a small leak in one of the raw water hoses in my 2009 wakesetter vlx. It is on one of the hoses that connect under the back seat. I didn't look to where it went but I assume it connects to the impellar. Are there replacement hoses or do you just use a car radiator hose?
thanks,
Joe
Old     (paulharenberg)      Join Date: Jul 2007       09-09-2019, 6:55 AM Reply
Something like this?
https://www.skidim.com/prodinfo.asp?number=MPI100-1140
Old     (dogs)      Join Date: Oct 2009       09-10-2019, 4:07 AM Reply
perfect. Thanks
Old     (TTyler89)      Join Date: Jun 2015       09-12-2019, 12:24 PM Reply
A heads up on any of the marine hoses, it’s easier to cut it with a metal chop saw that has a composite blade on it. It smokes like all hell, but puts a clean cut on it. Then slide a pair of dykes and push the rubber down on the wire coming out and cut it off so that the wire doesn’t protrude from the end. Your hands will thank you for that later.
