Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 04, 2009
Old     (99_air_warrior)      Join Date: May 2008       10-04-2009, 12:21 PM Reply
I'am installing a mid ballast in my centurion Elite Air and I wondering if I needed to vent it ? I have a brass check valve on the fill and a plastic check valve on the drain side. the bag will not be able to fill all the way due to the space provided. Should I just tee into the existing air vent for the rear ballast? I seem to have an extra through hull fitting on the starboard side and some kind of vent cap on the port side. the fuel tank filler is on the starboard side. any help, Thank You Joe
Old     (bbordin)      Join Date: Sep 2009       10-04-2009, 7:12 PM Reply
What bag are you using?
Old     (99_air_warrior)      Join Date: May 2008       10-05-2009, 5:56 PM Reply
Going to use a fly high v-drive bag I think its 18x18x42 THank You Joe
Old     (chpthril)      Join Date: Oct 2007       10-06-2009, 6:09 AM Reply
$.02 I prefer to vent the sacs. Over time, they will collect air, which takes up space that could be occupied by water. The vent will also prevent the sac from filling up like a balloon and having something give.
Old     (99_air_warrior)      Join Date: May 2008       10-06-2009, 7:21 AM Reply
Thank You, That's the info I needed Joe
Old     (dohboy)      Join Date: Aug 2007       10-06-2009, 2:48 PM Reply
Vent it or you can pop a bag
Old     (xstarrider)      Join Date: Jun 2007       10-06-2009, 8:31 PM Reply
Vent the bag for sure
Old     (talltigeguy)      Join Date: Sep 2003       10-06-2009, 9:36 PM Reply
There was once a picture circulating where a vent hose got kinked and rather than the bag popping, the entire rear corner of the boat had a nasty fiberglass 'rupture' if you will. So, the answer is to vent your bag whenever possible...
Old     (99_air_warrior)      Join Date: May 2008       10-10-2009, 8:24 PM Reply
Do you just install another thu hull fitting ? or do you need some other thu hull air fitting with a cap. I was planning on running another 3/4 inch line to a thru hull fitting, next to the drain Thank You Joe
