The belly tank is 350 lbs. The batteries are under the far stbd back seat and the port corner cushion. The flight clips are drilled to the tower in 2003 and clamps in 2004. I like these clips. They have never failed me yet. The guages have a built in depth guage, depth alarm, hour meter, water temp, air temp, gas consumption, volts, oil pressure, speedo calibration and a built in warning system for the engine (overheat (yes it works), knock sensor loose, etc) Hope that helps
