Old     (MooSeMan)      Join Date: Sep 2017       03-09-2018, 3:51 PM Reply
This guy wanted his Plank Remove from 29' Sea Ray and Reglassed and spayed with Gel Coat...
NEVER replace the Molding from a boat ,,,ONLY if you have to ,That stuff is put on at a Factory...
Old     (Stazi)      Join Date: Sep 2011       03-09-2018, 3:59 PM Reply
Why would he want to remove it? Weird
Old     (MooSeMan)      Join Date: Sep 2017       03-10-2018, 11:42 AM Reply
I don't ask WHY ,I take there $$$ and give them what thay want...
Old     (infinitysurf)      Join Date: Apr 2017       03-10-2018, 3:55 PM Reply
Looks like you did a good job with that, none of that work looks easy
Old     (Stazi)      Join Date: Sep 2011       03-11-2018, 6:41 AM Reply
Old     (denverd1)      Join Date: May 2004 Location: Tyler       03-12-2018, 9:06 AM Reply
the moose doing rubrail work!!!
Old     (MooSeMan)      Join Date: Sep 2017       03-15-2018, 9:19 PM Reply
Pulling the Molding off ,it helps to have a helper so you don't fold the Molding ,and If you don't have a helper ,,,You leave the last screw in and the middle screw in and the first screw in ,,, Tape the Molding to the boat ,then take the screws out and the molding wont fold on you ,the molding strip on this boat were about 15 feet ,,,It just helps if someone holding the End ,when you get to the last screw...
