Ok here is my problem. I have a 2003 SAN that originally had hard tanks and I piggy backed a 400 fat sac on top that was filled via the vent of the hard tank. I always had a problem with once they are 3/4 full the water is pushed back out through the empty pump (rule 1100 aerator). The easy fix is to push a cork into the outside of this hole and remove it when we are ready to drain. But, this completely does away with leveling the boat while riding. I've heard that running the empty hose up higher (more forward) will solve this issue. Is there anything else that needs to happen (anti siphon loop valve or loop). I'm trying not to get into reversible pumps or drilling holes in my boat. Thanks for any help
