Old     (Laker1234)      Join Date: Mar 2010       09-21-2014, 12:03 PM Reply
What is the best grease to use on boat trailers with disc brakes? I was at the parts store and the marine grease container read “not for disc brake bearings” and “not for continued underwater use.’’ I understand the latter but what is the difference of grease for trailers with disc brakes?
Old     (meathead65)      Join Date: Sep 2006       09-21-2014, 5:25 PM Reply
Disc brakes generate and transfer more heat to the hubs, so disc brake spec grease typically has a higher viscosity, or at least a higher resistance to liquefying.
Old     (Laker1234)      Join Date: Mar 2010       09-21-2014, 6:05 PM Reply
Never thought of that, thanks. So some type of lithium grease is what I need?
Old     (chpthril)      Join Date: Oct 2007       09-21-2014, 7:19 PM Reply
You need a wheel bearing grease period, marine specific is better. Lithium doesnt necessarily mean its meant to handle the heat and pressure of bearings.
Old     (Laker1234)      Join Date: Mar 2010       09-21-2014, 9:05 PM Reply
Thanks!!!
