Old     (gravity)      Join Date: Jul 2009       12-20-2014, 1:42 PM Reply
So I have a straitline rope. My question is how the heck are you guys getting the smaller extentions apart? They seem to have almost melted together. I don't want to shove something in between and pry. Is that what I should do? What are you all doing?
Old     (boardjnky4)      Join Date: Dec 2011       12-20-2014, 2:17 PM Reply
Gonna have to pry it apart
Old     (GoneBoatN)      Join Date: Jun 2014       12-20-2014, 8:34 PM Reply
Where a loop of the rope goes around the other segment of rope, stick your thumb nail under it and sort of roll it back the segment of rope it is wrapped around. Work each loop a few times that way and it should come apart easily. I say roll because if you just try to pull on it with it being bound so tight it will not budge a bit. I would not use anything sharp to try and pry it apart as you can easily damage the fibers.
Old     (alexair)      Join Date: Oct 2008       12-21-2014, 2:03 AM Reply
Regard your photo - you need just pull upper (exactly on your photo) loop in opposite directions and knot will be a loose enough for separate your rope. Also you can make this place wet. And this pulling may take some power but not so strong - just you will see as the knot became different. Sorry for my pronounce
Old     (snork)      Join Date: Jun 2007       12-21-2014, 5:24 PM Reply
just work it and if that dont work leave it alone
Old     (Redheadd)      Join Date: Apr 2014       12-21-2014, 9:23 PM Reply
I Usally twist the rope and push it through
Old     (wakebordr11)      Join Date: May 2001       12-22-2014, 7:08 AM Reply
Send it to me and buy a new one, it's ruined.
What alex said, pull that top loop, work it back and forth, you'll get it in a few minutes.
Old     (gravity)      Join Date: Jul 2009       12-22-2014, 10:43 AM Reply
Thanks everyone. I got it. All good suggestions.
Old     (buffalow)      Join Date: Apr 2002       12-22-2014, 12:29 PM Reply
We smack the not against a hard surface/head a few times, pry apart, smack/pry. Few times it will come right out
Old     (lovin_the_wake)      Join Date: Jul 2007       12-30-2014, 8:48 AM Reply
That's what's always worked for me. Lay it on a hard surface and hit the knot with a hammer, it works really well
