Old     (jaed)      Join Date: Feb 2012       06-11-2013, 9:58 AM Reply
Not sure if this has been talked about.
Looks interesting.
http://www.youtube.com/watch?v=CF9_-q4TbF8
http://www.centurionboats.com/news/n...ts-system.html
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 9:59 AM Reply
its in the 2014 update thread a few post down
Old     (grant_west)      Join Date: Jun 2005       06-11-2013, 12:46 PM Reply
Centurion seems like they are always left standing when the music stops. They have come out with some pretty amazing stuff and in some cases YEARS before anyone else does. Game Changers before people knew what Game Changers were. But they never seem to benefit. It's like until the big 3 take it on or add it to their line up no one seems to care.? And for the record No one cares who Was "First or Last" to start doing this or that. No one cares that this company copied that company.
Brand Loyalty is slowly going by the way side. If what you have TODAY is not the latetest and greatest then it matters little what you did 20+ years ago in a sport/ industry that is all about what's next?
Quick Fill and empty ballast with no pumps = Awesome.
The claim Fastest filling system in the Industry?? It's faster then Pure Vert? But you can't fill put vert on plane.
The Ability to pull up a rider and not have to pull 3000lbs of ballast up to speed and then have the ability to fill then ballast b4 the rider can pull down shorts and cut out =Brilliant
If this system works as good as it looks then IMO it is truly a game changer.
My critical eye sees some things that could use work. All these things need to be automatic and tied in with Perfict Pass. Example your boat is sitting in the water ready to pull a rider up Empty ballast. Driver hits it and as soon as the boat is at set speed it automatically fills or opens up the ram fill. As soon as the rider go's doe and the driver pulls back on the throttle it dumps ballast.
All this is being done with out the driver doing anything. IMO the driver needs less things to do and not more so he or she can focus on the task at hand. So the question is going to be Who Is it that's going to take this Idea and perfect it? Will centurion finish what they started or let the bigger fish eat their Idea
Old     (norcalrider)      Join Date: Jun 2002       06-11-2013, 2:12 PM Reply
I remember seeing a video of some ol' timer who had a system like this handmade and was looking for funding. Anyone remember what I'm talking about?
EDIT***
This video:
http://www.youtube.com/watch?v=lYJ85CEc2Sw
Old     (boardman74)      Join Date: Jul 2012       06-11-2013, 2:18 PM Reply
Wasn't the dude who invented the air chair. Mike something.
Old     (you_da_man)      Join Date: Sep 2009       06-11-2013, 2:18 PM Reply
I wonder at what minimum speed the ballast can drain. Say in the case of a fallen wakeboarder. Can you empty the ballast after the boat settles, makes the 180, and idles back to the rider. Is that "no wake" speed enough to empty to take advantage of pulling up the rider empty then filling again.
Old     (polarbill)      Join Date: Jun 2003       06-11-2013, 2:23 PM Reply
Does the ballast have to empty when it comes off plane? I wonder if you had the empty ports open if just pulling a rider up would empty the ballast enough to help it get on plane easy?
The problem with draining any of the ballast when the boat starts to slow is that unless the vent side or outgoing ports close the water will just all fill back into the hull once the boats slows and the exiting ports are under the water line.
For now maybe the idea isn't to have the ballast fill and empty when a rider falls/gets up but just to be able to switch it side to side quickly?
That other system is the old calabria guy. I can't think of his name but he was the one that invented purevert when he owned calabria I believe.
Old     (boardman74)      Join Date: Jul 2012       06-11-2013, 2:32 PM Reply
Yeah thats the guy Brett. I think it's mike something. Looks like a burned out crazy surfer dude!!
Old     (polarbill)      Join Date: Jun 2003       06-11-2013, 2:41 PM Reply
Mike Murphy I believe.
Old     (boardman74)      Join Date: Jul 2012       06-11-2013, 2:52 PM Reply
Thats it!!
Old     (shawndoggy)      Join Date: Nov 2009       06-11-2013, 3:34 PM Reply
yeah this solves some of the issues with pure vert (fill while moving), but isn't really the full blown second gen system like that video.
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 3:40 PM Reply
Brett, on the current Centurion Quick Fill system you must be at speed when emptying, and if you slow down, the gates close. So you don't take on new water, but you also don't empty out water.
I suspect for wakeboarding, this will be pretty huge for the riders that want massive wakes without having to buy huge engines for the hole shot, You can start off empty, then fill those suckers all the way up on a plane and it will be less work on the boat and more fuel efficient Of course, when the rider falls, its 30 seconds to empty some of them if you don't want to start off with the weight.
Old     (shawndoggy)      Join Date: Nov 2009       06-11-2013, 3:42 PM Reply
right. any fill-on-plane benefit only really applies to the first pull of the day. meh.
Old     (polarbill)      Join Date: Jun 2003       06-11-2013, 3:44 PM Reply
Thanks Carzin. It sounds like a great start to the system I am just not sure how much water would actually drain from when someone starts to pull back the throttle till the boat is going slow enough that water could come back in or the gates shut. The outgoing ports would have to be huge I would think to let much of the water go out in the slow down time or from when you first hit the throttle to affect the plane time.
Old     (krbaugh)      Join Date: Mar 2002       06-11-2013, 3:47 PM Reply
G
Since Centurion had the wake plate, ballast and speed control integrated with
there computer and custom profiles for each rider. I would bet that cats and ram file are also integrated with the computer
and can have custom profiles for each rider.
My quick fill is fast enough for me but WOW I need .... have to have the CATS!!
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 4:08 PM Reply
Yeah, I agree that the cats are the best thing. Already talking to my dealer to see if it can be retrofitted.
Old     (krbaugh)      Join Date: Mar 2002       06-11-2013, 4:41 PM Reply
GREAT minds think alike :-)
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 5:01 PM Reply
im thinking they may have some "bugs" to work out on there new system.....
Old     (craigtxmc)      Join Date: Oct 2008       06-11-2013, 5:10 PM Reply
Ha
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 5:39 PM Reply
Where did you get that picture, runin? And what were the circumstances?
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 5:49 PM Reply
I'm not going to say where...but from what I was told it was at the centurion dealer only demo days. They had to swim to shore and retrieve boat from bottom of the lake
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 5:56 PM Reply
So, you don't know if the boat sinking had anything to do with the system?
R&D boats are finicky. Anything number of things could have happened that you wouldn't see in a production boat. I can't imagine they would be issuing a press release with new features after the boat sank if some critical design flaw was found.
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 6:05 PM Reply
It was a system flaw...maybe not whatbunwould see in a production boat. BUT you would think hat dealers only demo wouldn't be a "r&d" boat when they are trying to get dealers excited about the new boat they are pushing to sell
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 6:09 PM Reply
If they only have one boat that has these features, you can be pretty confident it is an R&D boat. Given that it appears to be the same hideous yellow color that was shown in the movies, it is probably the one and only boat they have right now. I owned a former Supra R&D boat. They can look just like production, but then again, they are being tweaked over and over again, and things can get missed. R&D boats are not built to the same standards, and often get reconfigured with non production parts and assembly techniques.
So, I'll ask one more time. Do you actually know the circumstances that lead to the boat getting sunk, or are you just speculating that because it has a new ballast system, this is what must have caused the problem? If you actually spoke to the guys when it happened, and they told you some stuff, I'll take your word on it.
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 6:10 PM Reply
It was a design/installation failure
Old     (chattwake)      Join Date: Jan 2010       06-11-2013, 6:12 PM Reply
Haha whoops!
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 6:14 PM Reply
I guess you are being cryptic for a reason, because you aren't explaining why you, a non Centurion owner or rep, knows this boat sank because of a design failure. A design failure is completely different from an installation failure. A design failure would be something that would fail even if everything was installed perfectly. An installation failure would be that someone didn't install or build something correctly (not to spec) that caused a failure.
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 6:16 PM Reply
I wasn't ever talking bad about the boat..just posted a pic of one that didn't go as planned. I actually like the boat and the cat fin to shape the wake
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 6:24 PM Reply
Understood. I was hoping for details, like "The Centurion Rep swam in and said the RAM system failed and flooded the boat". All I see is a sunken boat right now. I have to think Centurion won't be releasing a boat that will be sinking on all their owners, and I would also think they would be really hesitant to issue a release on new features, given the sunk boat, unless it was something stupid that occurred or an easy fix.
For me, the biggest feature is the CATS. I hope there is some possibility to retrofit my boat with it, but I suspect they will be adding some additional fiberglass support in that area, and it won't be possible. Bummer.
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 6:27 PM Reply
It was the ram feature that failed but I don't know the specifics of why. Boat sank in 20 seconds is what I was told
Old     (WakeDirt)      Join Date: Jun 2011       06-11-2013, 6:35 PM Reply
LON was hesitant at first...now he officially pulled the trigger on a FX44.
Old     (grant_west)      Join Date: Jun 2005       06-11-2013, 6:39 PM Reply
Ummm I guessing this is Never gonna happen. This system seems like its built around the boat. I don't think is is somthing like Surf gate or a wake plate or a wedge you could just bolt on. "palms to face"
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 6:58 PM Reply
Dude, while you are probably right, this is still an Enzo hull and they likely did a slight cut out for the plate and maybe some reinforcing from the inside. It's not out of the question. 'Palms to the face' right back at you.
Old     (grant_west)      Join Date: Jun 2005       06-11-2013, 7:25 PM Reply
I see your Palms in your face and I raise.
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 7:38 PM Reply
Carzin....update
It wasn't a design flaw. The boat had 6" holes to see in the tanks. Someone forgot to screw them back down. When the water rushed in.. It really rushed in.
User error. Like leaving the drain plug out times 50
Lol
Old     (CarZin)      Join Date: Feb 2011       06-11-2013, 8:03 PM Reply
Ok. That makes sense. One helluva expensive mistake. Clears this up nicely.
This board seems to be so critical of anything not Malibu, Correct Craft, or Master Craft, its important to get all the facts right in cases like this. I appreciate you getting the details for the thread.
Old     (runin90lx)      Join Date: Sep 2009       06-11-2013, 8:08 PM Reply
I own and love my MB boat...I know all about the big 3 co&# stroking around here lol
Old     (boardman74)      Join Date: Jul 2012       06-11-2013, 8:30 PM Reply
What do you guys mean? I've never seen anything like that on here!!!!!
Old     (MattieK27)      Join Date: Mar 2010       06-11-2013, 8:53 PM Reply
I typically see more MB & Tige stroking and big three bashing than anything else on Wakeworld, hell the Centurion owner in this thread almost lost his mind when a picture of a sunken boat got posted...
Back on topic, I really like what Centurion is doing with their line. Has anyone seen an FX22 in person yet? I am interested in what I have seen online and in brochures, but have not seen one on the water yet. I wonder if these new systems will be offered on the FX...
Old     (grant_west)      Join Date: Jun 2005       06-11-2013, 8:58 PM Reply
Ok CarZin your either real handy with tools and you know a lot about boats or you have no clue. Be honest witch one is it?
The way I see it. Centurion comes out with some cool new features to get people to BUY a new boat. Why would you buy a new boat if you could just buy up grades from the factory that made your boat up to date. The factory's goal is to get you to buy a new boat NOT to sell you parts.
And think about the liability and problems having a guy doing this type of upgrades would bring?
Lol I want to see the 300 page instruction book that comes with this upgrade retro fit
Old     (WakeDirt)      Join Date: Jun 2011       06-11-2013, 9:04 PM Reply
Ya there is one at my nearest dealer, it is red with a tan interior, they are so so sweet. Very expensive, but they are a well made, very roomy boat.
Old     (surffresh)      Join Date: Jun 2010       06-12-2013, 5:45 AM Reply
I am going to step out on a limb here, IMO Centurion pricing has sky rocked up faster than any other brand, I wonder what these new toys will do to their price and if they are options or standard and what will it cost to retro fit a late model, I don't see the RAM quick fill being a retro fit option but what do I know. Flyboy had an interesting blog on all of the new surf innovations including CC, BU, Tige, and these from Centurion. The envelope keeps getting pushed and it's all good.
Old     (CarZin)      Join Date: Feb 2011       06-12-2013, 6:29 AM Reply
Well, I am not entirely sure, but I 'recall' that the NSS system, while it came out on the 2013 Nautique models, was a retrofitable option for the 2012s that were sold. Retrofit options are not unheard of, but admit they are rare. No way in hell RAMFit would be, and its still unlikely that the CATS would be, but I think it would be within the realm of possibility. Not saying it is going to happen, but it won't stop me from asking.
My dealer has sold a few FX-22s. Personally, they aren't for me. I don't like the design, and we don't use the bow, so we don't need to spend the premium to get a bigger bow area. But they are unique.
Old     (wakedaveup)      Join Date: May 2012       06-12-2013, 11:26 AM Reply
"reintroduced RAMFILL tech", it's not new technology, more so refined. I believe Epic uses a similar system and much props for pushing that envelope. Definitely not "new" technology. Shoot I think Mike at Sky Ski was trying to retrofit this on a Calabria years ago.
Old     (CarZin)      Join Date: Feb 2011       06-12-2013, 11:39 AM Reply
It is interesting how this stuff waxes and wanes. A few years ago, it was the switchblade. Then all of a sudden, no switchblade.
I think the computerization of all these components in making their management possible which is something we didn't have in the past, not to a significant degree.
Old     (migs)      Join Date: Aug 2006 Location: SF Bay Area       06-12-2013, 11:42 AM Reply
^^^ did they get rid of that God aweful peice of engineering the SWITCHBLADE?
Im nursing 10 stitches and loosing all of June to ride because of that POS!
Old     (CarZin)      Join Date: Feb 2011       06-12-2013, 11:52 AM Reply
Yeah. I don't think it has been offered as an option for a few years now. Maybe 2011 was the last year?
What happened?
Old     (migs)      Join Date: Aug 2006 Location: SF Bay Area       06-12-2013, 1:43 PM Reply
just dove in the water from the swim deck and my foot smacked the switchblade & sliced my foot to the bone. 30 minutes before my other buddy sliced up his shin on it as well.
thats some impressive engineering when someone who jumps in the water from the swim deck can get that injured. freakin POS.
Glad its no longer available.
Old     (CarZin)      Join Date: Feb 2011       06-12-2013, 3:46 PM Reply
Yikes!! Centurion OEM'd it. I wonder if injuries like yours is one reason they dropped it.
Old     (wakerider111)      Join Date: Jul 2006       06-13-2013, 12:05 AM Reply
Sooo... i might have missed it, but how much weight is going into the boat with this ramfill thing???
Old     (wolfe_drew)      Join Date: Mar 2010       06-13-2013, 11:46 AM Reply
Already been said, but I'm assuming that this is an R&D boat. Anybody remember that Mercedes commercial where they showed car after car being slammed into a wall to show how they tested for safety? I'm glad Centurion put it at the bottom of the lake vs one of us!
I haven't worked for a boat manufacturer, but I would guess that they all sink boats when testing new ideas and concepts and in working to make sure that us idiots don't find an easy way to hurt or kill ourselves, our families or others.
I'm excited to see the innovation and think it's great that they went to such lengths and expense to make sure it's a safe product to have on the water.
Old     (CarZin)      Join Date: Feb 2011       06-13-2013, 11:56 AM Reply
"Already been said, but I'm assuming that this is an R&D boat. "
As posted above, there was some inspection plugs for the ballast system that were not replaced before the test drive, and when they engaged the RAM, the water flooded the boat. Was just user error.
Old     (wakedaveup)      Join Date: May 2012       06-13-2013, 12:07 PM Reply
Wasn't this a brand new boat (regardless of R&D)? Why would plugs need to be replaced on a 2013 model? Does that mean people purchasing that boat should worry about replacing ballast plugs in the first year that they own the boat?
Old     (wakedaveup)      Join Date: May 2012       06-13-2013, 12:08 PM Reply
For the record that wasn't a bashing statement it was an honest question. Just seems weird to have to replace plugs on a boat that was just built.
Old     (jhartt3)      Join Date: Jan 2012       06-13-2013, 12:12 PM Reply
Seriously dude. its not replacing plugs... its putting the plug back where it goes just like you replace your drain plugs on your boat each time you go out... cmon man ... you're bashing just to bash...
let me explain simpler... they took them off of the place they were that makes the boat function properly ... they then had to put them back in that same PLACE ... so they rePLACED them... they didnt have to buy new ones...
Old     (wolfe_drew)      Join Date: Mar 2010       06-13-2013, 12:18 PM Reply
As somebody else stated, an R&D boat is exactly that and it has features, functionality and accessories that a production boat may not have. My guess is that those plugs won't be in the production boat so num-nuts like us don't find our boat at the bottom of the lake.
Old     (chattwake)      Join Date: Jan 2010       06-13-2013, 12:21 PM Reply
^^^ You'd have to get the special LON-Fill edition boat to get those removable plugs.
Old     (wolfe_drew)      Join Date: Mar 2010       06-13-2013, 12:32 PM Reply
bwahahaha!
return of the Lon.
Old     (wakedaveup)      Join Date: May 2012       06-13-2013, 12:39 PM Reply
Lol ok bud. When they used the word "replaced" I mistakenly took that as the original ones needed to be replaced already (because they were bad, not because they weren't there). Calm down it's just a question haha. I have nothing against centurion and think a 30 second fill time is freaking amazing..... so again, calm down lol.
Old     (wakedaveup)      Join Date: May 2012       06-13-2013, 12:42 PM Reply
And if you look at CarZin's post, he actually used the word "replaced" not "forgot to put back in". Not his fault, but please chill out for taking one word wrong.
Old     (CarZin)      Join Date: Feb 2011       06-13-2013, 1:25 PM Reply
Yeah, I suspect they were inspection ports. Since it was an R&D boat, you want an easy way to check the tanks to make sure they fill and empty completely.
Old     (onthecreek)      Join Date: Apr 2013       06-13-2013, 1:47 PM Reply
^ agreed....if it was a dealer demo then there might have been viewing ports installed similar to 3:33 in this video
Old     (Bam6961)      Join Date: Apr 2011       06-13-2013, 11:03 PM Reply
I'm curious on how much drag the ramfill causes when ballast isn't filling. i assume it would be alot and effect the GPH, how much would it effect it is the question?
someone should do a comparison when it comes out.
Old     (wakerider111)      Join Date: Jul 2006       06-14-2013, 9:54 AM Reply
"It's a no brainer" ... gona have that stuck in my head
Old     (wakerider111)      Join Date: Jul 2006       06-14-2013, 10:29 AM Reply
so the current centurion catalog says that the aprox max ballast is 3,900... can we then assume that this is about the same weight? if so that is about 3 times faster fill time than vert ballast on the epic 23v if i have my numbers right
Old     (CarZin)      Join Date: Feb 2011       06-14-2013, 11:08 AM Reply
The ballast for the centurion is as follows:
244: 4575
233: 4225
FX22: 4400
211: 3625
If you look at the previous annoucement of the FX44 and the RAMFill (a couple months ago), they claim the fastfill to not sacrifice the ballast numbers, but they may come in a little bit lower.
Old     (wakerider111)      Join Date: Jul 2006       06-14-2013, 5:59 PM Reply
yup, must have missed that one^^^ thanks
i guess centurion now takes the cake for factory ballast in just about every way.. over 4,500 lbs. crazy
Old     (WakeDirt)      Join Date: Jun 2011       06-23-2013, 8:05 PM Reply
Any news on a retro for cats?
Old     (Mrusso)      Join Date: Sep 2013       09-22-2013, 6:29 AM Reply
Hi guys,
I used to frequent this board awhile back under a different user name that I can't remember.. anyway, stumbled across this thread, and figured I'd add what I posted on the the malibu board the other day.. If any one's interested..
I've been watching this thread because my marina has been considering taking on the Centurion Line.. Yesterday we met with the north east sales rep and demo'd a new SV244 with the ram fill and cats system... I have to say, both are impressive. The ram fill does in fact fill in less than 30 seconds and there is no additional ballast needed. We never even filled the bow tank.. I know total ballast on the boat was about 4600 with the bow tank full.. not sure what the two rear tanks add up to but the surf wave as well as wakeboard wake was insane. As for filling and dumping for each pull.. not practical, but doable I guess.. The first pull of the day, sure, but idling back to the rider wouldn't give you enough time to fully dump the ballast.. On plane it dumps In about 30 seconds. Again, not sure where the notion that these boats require additional bags came from, but we only had two people on board and didn't even fill the bow tank and the surf wave was scary big (I'll admit I'm a novice surfer though..) Keep in mind these boats are a true deep V hull so they displace a lot more water than a flat bottom boat with the same amount of ballast.. Now the CATS.. Essentially, it does the same thing as the surf gate, NSS, etc. by crabbing the boat.. Its basically like a rudder mid ship. You can actually steer the boat with it, which is weird at first, but basically you adjust it to whatever side you want to surf and your crabbing.. Now what makes it cooler than surf gate in my opinion (dont get mad, I'm still a Malibu fan ) is that you can use this function at any speed. You can dial in your wakeboard wake with or adjust for an unevenly weighted boat at any speed.. During the demo we put everyone on one side of the boat (just like all my dumb *** friends do and it pisses me off when I'm running down the lake listing to one side) and we were able to instantly level the boat off by adjust the tracking fin to one side, which actually tries to steer the boat and as soon as you counter steer with the wheel you can level it off with out ever moving people or ballast. Honestly, I think that Impressed me the most.. Consequently, you can use this feature to dial in the wake, again, with out messing with ballast or moving people. Now someone mentioned how hard it must be to drive this boat because you have to "fill, adjust cats, trim tab, blah blah" The boat actually does everything automatically.. Even before you save a setting as a preset. For instance if you set the cats system to compensate for an unevenly weighted boat and the rider falls. As soon as you bring the boat to idle it centers the tracking fin so that it doesn't effect the boat handling during idling, docking, starts ect. As soon as you come back up to speed it will go right back to where you had it. The ballast remains full however but will fill/empty automatically for a selected rider preset.
I'm sure some of you are wondering, is there anything I didn't like about the boat? . My one complaint was that the boat was noisy. At high speed and on starts it had a little vibration till it planed off and it was just loud inside. Not exhaust loud, just overall kinda noisy. To be fair however, I haven't been on a wake board boat filled with ballast that was truly smooth and quiet, so it could the nature of the beast.. Albeit, its worth noting.
All in all, I think they really did a great job with the boat. Its functional and they executed these ideas very well. The user interface on the touch vision or whatever its called is very easy to use and well thought out.. I love Malibus, I run a response barefooter every weekend and its still the best barefoot/slalom wake I've ever skied. I just wanted to contribute some hopefully useful insight to this discussion.
Old     (you_da_man)      Join Date: Sep 2009       09-22-2013, 11:06 AM Reply
^^^ nice write up. Did you test/sample both reg and goofy surf wake and how did they compare to each other as far as being clean as Centurions seem to favor reg side unless RH rotation is opted for (I know this area of the Enzo has improved in the last couple years).
Old     (CarZin)      Join Date: Feb 2011       09-22-2013, 1:47 PM Reply
Centurion is so sure they have fixed this issue with CATS , that right hand drive is apparently not even an option for this model.
Old     (Mrusso)      Join Date: Sep 2013       09-22-2013, 2:40 PM Reply
We ran both sides, and they were pretty much the same.. In addition to the CATS fin, I'm pretty sure that was part of the motivation behind the Asymmetrical trim tab.. Either way, we had no issue dialing in a nice clean wave on either side.. If i had thought I'd be posting up about this I'd have taken some pics.. but all I got was a video of us barefootin off it.. go figure.. haha
