Looking at the feature comparison it looks like the 215 has some additional features:
- High-performance Variable Trim System (VTS)
The high-performance VTS allows you to adjust the attitude of the watercraft based on rider weight, riding style and water conditions – giving you better control and customized riding characteristics. The high-performance version includes 2 preset options.
- Ski Mode
This advanced iControl feature allows the driver to adjust the intensity of the launch for different rider skill levels and tow sports while maintaining a constant speed. You get highly repeatable runs for the best possible tow sports experience
- Multi-function Digital Information Center
27-function digital information center with easy-to-read gauges for info at a glance, including fuel level, tachometer, speedometer, hour meter, compass, water temperature, time, fuel consumption meter, touring/sport mode, cruise control, Ski Mode, slow speed mode, VTS, VTS preset, F-N-R indicator, low fuel level, low oil level, low oil pressure, low voltage, overheat, hi-voltage, check engine, sensor check, key (battery protection), key (wrong key), L-key, maintenance info, error codes.
- iControl
Introducing iControl, the world's most advanced watercraft technology. Featuring a slew of firsts for PWC: an Intelligent Brake and Reverse (iBR), the first on-water braking system; Intelligent Throttle Control (iTC), with neutral, slow-speed mode, cruise control and Ski Mode (on WAKE Pro); and the S3 Hull, the first stepped hull design for a PWC. All of which add up to a safer, more responsive ride that will make other PWC obsolete. The world's most advanced watercraft is no longer a matter of opinion. It's a matter of fact.
- Tilt Steering
Adjusts the steering and information center angle for maximum ease and comfort.
215
http://www.sea-doo.com/en-US/watercraft/sport/wakepro/features.htm 155
http://www.sea-doo.com/en-US/watercraft/sport/wake/features.htm
