Again, this is the older 210 hull, pre-2007. 750's in the rear (I don't fill them slammed full, probably fill to 600 or so is my guess), 350 (?) in the center locker tank (better actually not to have the center locker tank and use the fat seat bottom identified above, if you can), triangle under bow seat in bow (I've always assumed this fills to like 400 just eyeballing it), and some extra weight up front (I've been adding 400-600 in a 750 lb bag, used to have about 300 lbs of lead) on the bow. I also usually add another fat brick (100) or custom sac (250) to the playpen area, depending on how many people are in the boat. I've found that you want weight up front to make the tranny longer (still steep as can be). Weight throughout the boat (not just bow and stern) also makes the wake really firm and the pull smooth (unlike a teeter-totter). Congrats, you're going to love it.
