Old     (heath)      Join Date: Feb 2008       03-10-2008, 5:30 AM Reply
Does anyone have any experience with repairing Gel Coat. I installed a pair of speakers over the weekend and when drilling the holes the gel coat chipped further than the hole itself. Probably about half the size of a dime per hole. Once the speaker went on you could not see the chips. Should I be worried about possible spidders developing later as a result of these chips or should I take the approach that if you don't see it then no harm.
Now that the holes have been drilled, can these chips easily be fixed with the common gel coat repair kit availabe at most marine stores?
Old     (cavlxenvy)      Join Date: Aug 2007       03-10-2008, 10:07 AM Reply
Tough to say without seeing what you have done.
Old     (mobv)      Join Date: Jun 2002       03-10-2008, 1:08 PM Reply
Maybe you know this but you should run the drill backwards to avoid chipping the gel.
If there in no stress on the gel from the speakers they will probably not develop stress cracks and run further. To repair you have to grind or sand the crack-away and then fill with gel-coat of the proper color. The hardest part is matching the color exactly.
