Old     (djsauer)      Join Date: Feb 2015       07-06-2016, 4:21 PM Reply
Just bought a new slingshot board. Am I dumb, or how the heck do you set up the bindings to the board? I was under the impression that the board would have screws or something as I've never used this kind of board.
Can somebody please explain this to me? I've attached pictures to help.
Old     (djsauer)      Join Date: Feb 2015       07-06-2016, 4:36 PM Reply
Never mind, found my answer. Apparently you have to buy the hardware separately... And yes, I looked throughout the box
Old     (svnfightsvn)      Join Date: Mar 2011       07-06-2016, 5:17 PM Reply
I thought all new slingshot boards with the fast track came with the pieces the slide into the track that you mount bindings to...
Old     (Onebadssv)      Join Date: Feb 2016       07-06-2016, 5:58 PM Reply
It should have come with it, mine did. You should have 4 square bottom mounts that's slide down into the channel and then a small bolt to go down through the bolt and into the bottom mount within the channel. I love that at anytime you can slightly loosen the screws and slide your boots closer or wider depending on rider.
Old     (djsauer)      Join Date: Feb 2015       07-06-2016, 6:57 PM Reply
Yeah, mine didn't come with unfortunately. That's kind of a pain in the a$$. Luckily, the cable park I'm going to should have them on Friday.
Old     (djsauer)      Join Date: Feb 2015       07-06-2016, 7:00 PM Reply
Now, I'm concerned about my bindings fitting on this board. Will CWB JT boots fit with this?
Old     (Kane)      Join Date: Mar 2010       07-06-2016, 11:43 PM Reply
Yes they will fit just fine.
