Old     (Lemonade)      Join Date: May 2015       08-30-2021, 3:08 PM Reply
Am i better off in a 2015 G23 or a 2019 SAN 230?
Very similar option specs, primarily surf, tow vehicle is 2020 F150 5.0L
Danke
Old     (Xbigpun66)      Join Date: Aug 2016       08-30-2021, 4:30 PM Reply
Towing wise you are better off with the 230. Surfing wise you are better if with the 230. Send like an easy decision.
Old     (Bret)      Join Date: Nov 2013 Location: Santa Rosa, CA       08-30-2021, 4:58 PM Reply
didn't you just buy a Sanger v210
Old     (Lemonade)      Join Date: May 2015       08-31-2021, 8:44 AM Reply
Yes, kids convince mom to upgrade so I was dreaming about boat's available. Most ppl here are saying G over 230 even though it's older
Old     (tre)      Join Date: Jul 2002 Location: WI       08-31-2021, 12:23 PM Reply
For the primary purpose of surfing, G, no question.
Old     (rlwagens)      Join Date: Feb 2008       09-01-2021, 8:17 AM Reply
Most people towing G23s with 1/2 trucks are doing so with no people/gear and empty gas tanks for short distances with upgraded tow packages/tires otherwise it’s a white knuckle experience. Something that should be a major factor to keep in mind unless you plan on upgrading the tow rig.
Like others have said, towing/surfing (if you don’t mind added bags/re-cycling ballast pumps/losing storage) and joy of driving/maneuverability of the boat = 230.
Just wanna drop the boat in and fill up and have solid surf/wakeboard wakes and storage/space galore = G23.
Old     (miljack)      Join Date: Feb 2006       09-02-2021, 11:01 AM Reply
I have a 230 and have ridden/surfed behind G23's. If surfing is 1st mission, and, towing with a 1/2 ton truck, 230. You'll have to add extra ballast, but the NSS will make the 230 surf wake really good w/extra weight. The surf wake won't be as "steep" on the 230 vs.G23, but, it's more versatile.
If you intend on any wakeboarding, the G23 has a better wake, easier to get there. Driving a 230, no question is a more responsive boat than the G.
