Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 06, 2005
Old     (robie)      Join Date: Mar 2004       08-27-2005, 4:26 PM Reply
I was out on the lake today and the speedometer on PP wasn't reading correctly. I tried to recalibrate it with no luck. I would be going around 20 and it would read 8. I was out last weekend and it worked perfectly.
Has anyone else had this problem or have any advice on how to fix it? My boat is a '00 X-Star if that helps.
Thanks.
Old     (rvh3)      Join Date: Jul 2003       08-27-2005, 5:09 PM Reply
Check the paddlewheel to see if it spins freely.
Old     (mjmurphy53711)      Join Date: Mar 2004       08-27-2005, 5:32 PM Reply
i went through a similar problem and it ended up being a low voltage issue, check the connects on your battery. just a suggestion....
www.wakecoupons.com
Old     (robie)      Join Date: Mar 2004       08-28-2005, 8:18 AM Reply
Where is the paddlewheel at? I didn't install this it came with the boat.
I wasn't having any other issues with electronics. I will take my voltage meter and see what I get out of it.
Old     (magnusm)      Join Date: Dec 2003       08-28-2005, 10:54 PM Reply
The paddle wheel will be under the boat, probably in the middle on the other side of the hull from the water intake. It's only a couple inches in diameter and doesn't stick out far below the hull. It's black plastic. If you crawl around under your boat you'll find it without too much trouble. Flick it with your finger and it should spin freely.
Old     (robie)      Join Date: Mar 2004       08-30-2005, 7:03 PM Reply
Thanks Rod and Magnus,
It looks like somehow I borke off one one arm of the paddle wheel. Should I contact PP to order a new wheel or would a dealer have that?
Any clue how much of a pain it will be to replace the wheel?
Thanks guys.
Old     (gmarkham1)      Join Date: Sep 2003       08-30-2005, 7:09 PM Reply
contact your dealer first otherwise pp will get one out quick, they generally come with an extra one!
They are super easy to replace!
Old     (rvh3)      Join Date: Jul 2003       08-30-2005, 7:09 PM Reply
Yes,
They will take care of you at PP.com. It will take you 10 minutes to replace the paddle wheel.
Old     (robie)      Join Date: Mar 2004       08-30-2005, 7:25 PM Reply
Thanks guys I will call them tomorrow.
Old     (jeffreyala)      Join Date: Dec 2004       08-31-2005, 5:23 AM Reply
I think the paddlewheel assembly is around $120.00
Old     (gmarkham1)      Join Date: Sep 2003       08-31-2005, 5:32 AM Reply
you dont need the whole assembly, just the paddle wheel and maybe a new axle!
Old     (robie)      Join Date: Mar 2004       08-31-2005, 9:28 AM Reply
The new wheels are $10 a piece. They ship them overnight. I got two just incase. Thanks for the help guys.
The PP were very friendly and helpful, great product + great service = a great company.
