Old     (TNwakeboarder86)      Join Date: Sep 2016       09-12-2016, 4:46 PM Reply
I am looking at an 04 centurion avalanche. Any one surf goofy behind one. With the walk thru I can't see goofy side getting a great wake. Currently behinf 05 supra 24 launch.
Old     (DuckHuntin1)      Join Date: Jul 2013       09-14-2016, 12:31 PM Reply
It has been done but I would not recommend it. Try to find a right rotation drive/prop and or C4 seating for the best goofy wave from an Avy.
Old     (TNwakeboarder86)      Join Date: Sep 2016       09-15-2016, 5:37 AM Reply
A c4? ok, what about the newer ones, the air falcon? I also was looking at a 2003 lsv moomba
Old     (jtryon)      Join Date: Jan 2015       09-20-2016, 11:49 AM Reply
a c4 avalanche doesn't have the walkthrough, so you can put a good amount of weight on both sides for a good goofy wake. centurion guys also have a mod called the "a-plate" or "asymmetrical plate" which helps clean up the goofy wake on a left-hand rotation boat.
Old     (TNwakeboarder86)      Join Date: Sep 2016       09-22-2016, 6:54 AM Reply
Josh, is that a diy thing or something you can buy?
Old     (DuckHuntin1)      Join Date: Jul 2013       09-24-2016, 2:26 PM Reply
both, you should be able to purchase an A-plate through a Centurion dealer or you can do a little digging on the triple C.
Old     (duffymahoney)      Join Date: Sep 2008       09-24-2016, 4:37 PM Reply
Avalanche c4 has an epic goofy wave, very little needs to be done.
Old     (TNwakeboarder86)      Join Date: Sep 2016       09-24-2016, 5:10 PM Reply
I have heard. The only boats I'm finding under 30k is not the c4...I'm finding a lot of moomba malibus under 25k. The 04 centurion avy I found is 18k.
Old     (delbert)      Join Date: Oct 2003       12-05-2016, 4:30 PM Reply
You still looking for a boat?
Old     (TNwakeboarder86)      Join Date: Sep 2016       12-06-2016, 5:44 AM Reply
I actually picked up a wakesetter, tested the avy then the VLX and went with the Malibu. With it being in UT country I already been offered more then I paid bc the college is UT colors. PErfect for vol navy. I might consider selling it to make a buck then buy again!
