Old     (granddaddy53)      Join Date: Dec 2013       08-23-2016, 11:29 AM Reply
What is the name of a transfer over to or almost to surface level and back without switching the actual wave?
Old     (Ryan23)      Join Date: Oct 2015       08-23-2016, 11:41 AM Reply
you talkn bout a floater?
Old     (granddaddy53)      Join Date: Dec 2013       08-24-2016, 8:33 AM Reply
Define floater ????, I went over and back and got pretty much to the flat surface of water/base of wave on other side of wave close to the boat in front , very similar to transfer switching the wave except I didn't initiate a crossing , I surfed and worked the foam until I got over and down and never had the driver switch the G23 wave
Old     (granddaddy53)      Join Date: Dec 2013       08-24-2016, 8:35 AM Reply
Wait , isn't a floater riding the foamy crest of the wave, stalling snd then coming down, so if that definitely not a floater
Old     (downfortheride)      Join Date: Jun 2005 Location: SLC, UT 5600'       08-24-2016, 11:59 AM Reply
How about video???
Old     (denverd1)      Join Date: May 2004 Location: Tyler       08-24-2016, 12:50 PM Reply
sounds like 2 cross overs
Old     (granddaddy53)      Join Date: Dec 2013       08-25-2016, 6:50 AM Reply
It was weak and my 1st day trying to cross after surfing foam for a month
https://www.facebook.com/daves.wakeb...2671676829474/
The HD long source vid for above below. Almost made it at :36 and check out totally backwards grinds at 1:05 and 1:15, 08 seconds above at 1:50
https://www.facebook.com/daves.wakeb...2673083496000/
Old     (granddaddy53)      Join Date: Dec 2013       08-25-2016, 8:11 AM Reply
Josh, were you in the supra for pro lessons at Surfest 2015? If so my wife was blond in wetsuit trying 360's and I was on crutches from broken femur
Old     (iShredSAN)      Join Date: Apr 2012       08-25-2016, 8:47 AM Reply
Old     (Chaos)      Join Date: Apr 2010       08-28-2016, 7:47 AM Reply
It is just a transfer. The combination of maneuvers or what you were doing are not a 'new trick' or a trick. It is just a transfer. Maybe a transfer out and transfer back if you want to get technical. People have been doing this for decades, long before quick switch systems.
Nick
Old     (granddaddy53)      Join Date: Dec 2013       08-30-2016, 11:21 AM Reply
Thx, still working on getting all the way to water surface, kind of scares me cause flats are close to boat platform
