My family just purchased a 2014 21ft Boston Whaler MONTAUK. We mostly use the boat for fishing but I enjoy wakeboarding and really want to start using it for Wakeboarding more. The only issue I can think of is the wake that it throws. The hull is relatively flat and im afraid the wake will be mushy and small. Does anyone have any advice on how to make the best possible wake for my situation? I have trim tabs and i figure if i put all the people on board in the back of the boat it will help.
Any advice will be greatly apprciated.
Thanks,
Mike
_________________
Michael Messler
21ft Boston Whaler Montauk
its got a 200hp mercury verado.. my only ocncern is the realtively flat hull.. im wondering where to put the weight? front or back of boat? and will the wake be good enough for inverts,flips,tantrums and big airs?????????
Bags of sand and concrete are cheap and easier to move around than fat sacs (when full) while you're trying to dial in the wake. I'd try 60% in the back and 40% in the front and play with the trim tabs to see what you can do. I started on a bass boat and was able to get decent air with no added weight..
Most wake boats have a pretty flat hull so that should not hurt you. Start with the weight around 60/40 rear/front and adjust it from there.you said you have a group of people that go with you and people are the easiest type of ballast to adjust. Most boats the more weight you put in the back the steeper the wake gets and the more in the front the rampier mellow it gets. As to whether or not you can do inverts and mobes with a smaller wake just Google some of Scott byerly video s from the 90's
I had an i/o with a pretty flat hull and put 300 lbs in the rear and 150 up front and it threw a good enough wake for flips....attempted flips anyway lol
