Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through March 27, 2008
Old     (wakechica)      Join Date: Jul 2007       03-11-2008, 8:59 AM Reply
I am wanting to learn to wakeskate but I have no idea of what size or kind I should get. I don't want to spend to much money in case I don't like it. I am 5'3" 150lbs. any ideas on size would be great.
Old     (sinkoumn)      Join Date: Jan 2007       03-11-2008, 10:21 AM Reply
You can essentially ride any sized skate, it's all personal preference. Do you have any friends that have a skate you can try out first?
Old     (electricsnow)      Join Date: May 2002       03-12-2008, 8:08 AM Reply
If you don't want to spend too much money, I'd just go with a flat deck, because it's only going to run you 100.00 or so. Or, you could look for a used wakeskate that might have some concave, like a hyperlite or some sort of compression molded deck, since those will last longer than a wood deck (but they're more expensive--brand new, a concave deck made of wood or compression molded foam can run you anywhere from 200-250.00).
as far as sizing goes, I'd recommend anything from a 40-41 inch board. As "sinko" said, you could essentially ride any size board, and go up to a 43 or so (I cannot remember how large they make them anymore, but they used to go up to 45 inches). A longer board is going to be a little bit more stable, but it's going to be more difficult to bring around if you try any sort of rotation. Furthermore, given that you're shorter, you're going to need a really wide stance on that thing...I would just stick with something in the range I've suggested.
I'm 5'3 as well and right now I'm on a 42 inch hampson bi-level, and I don't have a problem with it, but I certainly wouldn't go any larger, and I would not mind going smaller (and will be because now i have a 40 and 41 to choose from). If you've ever stood on a skateboard, you'll understand where the positioning of your feet will need to be, and then you'll probably be able to visualize what I'm saying about board length and stance.
Old     (sinkoumn)      Join Date: Jan 2007       03-12-2008, 8:13 AM Reply
Here ya go, not the greatest skate but it's a pretty good deal:
http://boardersmall.com/xcart/product.php?productid=18837&cat=342&page=1
Old     (wakechica)      Join Date: Jul 2007       03-12-2008, 10:33 AM Reply
Thanks for all your help guys, I think I'm gonna try to get that one from boarders mall on friday.
Old     (romes)      Join Date: Sep 2006       03-12-2008, 11:18 AM Reply
you also might want to check out wakeskating.com
you can always find some solid second hand decks on there...
