Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 04, 2009
Old     (tchs22)      Join Date: Sep 2005       08-27-2009, 6:07 PM Reply
Hey guys thinking of plumbing ballast into 2005 Ebbtide 210....what should I do? I have 2 250lb and 1 540 lb fat sac....just wanna make it easier to fill/empty sacs instead of moving pump from bag to bag....lemme know guys!! All opinions are appreciated
Old     (ferral)      Join Date: Sep 2007       08-27-2009, 8:16 PM Reply
Hey JT, here's the thread from my install.
Old     (tchs22)      Join Date: Sep 2005       08-27-2009, 8:47 PM Reply
hey lou theres no thread lol
Old     (ferral)      Join Date: Sep 2007       08-27-2009, 10:21 PM Reply
hahah, forgot to actually past the link. Here ya go:
http://www.wakeworld.com/MB/Discus/messages/3183/711154.html?1246838389
Old     (lfrider92)      Join Date: Sep 2008       08-28-2009, 7:05 AM Reply
make sure to get some weigh up front. weve got a 220 sea ray, and our boat would rather have 650 lbs up front. then 650 lbs in the front AND 750 in the rear.
Old     (epic1)      Join Date: Oct 2006       08-28-2009, 9:05 AM Reply
Why is that? Is the out drive pull our sterns under further than others?
Old     (tchs22)      Join Date: Sep 2005       08-29-2009, 9:41 AM Reply
hey guys thanks .....but now what kinda prop are yall using? we want one to be able to plane off quickly...
Old     (absoluteboarder)      Join Date: Aug 2002       08-29-2009, 2:18 PM Reply
def. get a lower pitch prop....you may have to experiment with a few to find what works more most of time with what ever weight config + people you have. We just used to buy aluminum props...they are cheaper and you dont feel so bad when you replace it with an even lower pitch.
we were torque hungry and didn't care how fast the boat went so you have to consider all that....finally you may have to keep an eye on the rpm so you dont go over....if you happen to drop the pith a lot.
Old     (tchs22)      Join Date: Sep 2005       08-30-2009, 6:44 AM Reply
I believe we have a 18 pitch prop on there now dad wanted a 16 or 14 can't remember........ Lou you ever get a new prop? How'd it work and what is it?
Old     (ktm525)      Join Date: Mar 2009       08-30-2009, 7:58 AM Reply
I am David,s dad. We have 4 people in the main compartment of out boat yesterday.,We filled the 750lb fat sac and had it in the bow on the floor. The wake was amazing. It was hard crisp and huge. I had the trim set at 4 speed at 22.7 on the PP stargazer. I have a Bravo 3 outdrive with 22 pitch props( we had 24 pitch, I changed them to plane faster)
Old     (ktm525)      Join Date: Mar 2009       08-30-2009, 8:11 AM Reply
Here is a picture of our wake yesterday. This is a friend of my sons learning to go wake to wake.
(Message edited by ktm525 on August 30, 2009)
Old     (tchs22)      Join Date: Sep 2005       08-30-2009, 10:44 AM Reply
yeah I mean we have a 550 in the ski locker and a 250 on each side. I ride at 75' at about 23-24mph....just wondering if i should have more weight....cause usually its one behind boat and two in boat...
Old     (drknute3)      Join Date: Sep 2008       09-01-2009, 11:31 AM Reply
I run a 22' Cobalt with 1100 up front and 540 in the rear. All is plumbed in, fill/drain on the fly at the flip of a switch.
Old     (tchs22)      Join Date: Sep 2005       09-01-2009, 12:08 PM Reply
Bill...does the front sink down a lot? I'm tryin to get as much info as I can so when we go up at end of October for last weekend of year we can get all this plumbed in and all....also what configuration you using with weight...thanks
Old     (drknute3)      Join Date: Sep 2008       09-01-2009, 12:18 PM Reply
It rides a little low in the front when full, but no more than any other boat would. Only takes a little roller over the bow if I have 3-4 peeps up front. I have 2 400# sacs up front in the stirage compartments and 300# of sand bags in the ski locker. Then have 2 260# side sacs in the rear on either side of the engine.
Running 2 Jabsco pumps. One fills the fronts and the other fills the rears. Each pump has its own 1" thru hull and switch on the dash. Each sac has its own vent so I know when they are full. When I drain, each pump pumps out thru the rear vents so I know when each pump is done.
Takes about 12 minutes to fill/drain.
Old     (tchs22)      Join Date: Sep 2005       09-02-2009, 8:05 PM Reply
okay well what kinda prop you running bill? we have a 18 pitch i believe and I wanna get more weight in but wanna plane off smoothly as well....
Old     (drknute3)      Join Date: Sep 2008       09-03-2009, 5:48 AM Reply
Mine is a Volvo outdrive so they are sized differently with duoprops. It came with an F6, and I switched to an F4 set. Kind of like going from a 21 to a 17 or thereabouts. Way better holeshot and speed control at boarding speed. Picked up abou 600 rpm on topend so I have to watch the revs at WOT.
Old     (tchs22)      Join Date: Sep 2005       09-03-2009, 7:14 AM Reply
I believe thats what mine is......a volvo outdrive... But yeah where you get prop from? and thanks for the advice its really helpful
Old     (drknute3)      Join Date: Sep 2008       09-04-2009, 6:38 AM Reply
I found my f4 set on ebay. Sold my f6 props on ebay as well. Actually made a few bucks as well.
