Old     (Laker1234)      Join Date: Mar 2010       06-29-2017, 5:21 PM Reply
The O-Rings at the hardware store are too thick. I need two O-Rings for the part that is not on the Tsunami Pump. Any suggestions to finding one is appreciated.
Old     (Xbigpun66)      Join Date: Aug 2016       06-29-2017, 5:55 PM Reply
Barefoot intl.
Old     (Laker1234)      Join Date: Mar 2010       06-29-2017, 6:25 PM Reply
Thanks!!
Old     (meathead65)      Join Date: Sep 2006       06-29-2017, 9:26 PM Reply
Find a local hydraulic hose shop, they will have a much wider selection of orings than the hardware store.
Old     (dyost)      Join Date: Jan 2007       06-29-2017, 10:37 PM Reply
Ron, where did you go? Most hardware stores should have a pretty good selection of O-rings, including different cross section diameters. My local True Value (town of about 6000) has a ton of options.
If you can't find a suitable replacement I would try Wakemakers. If they don't have them, they probably know where to get them.
Old     (jonblarc7)      Join Date: Jul 2006       06-30-2017, 5:39 AM Reply
Napa should have a good selection
Old     (racer808)      Join Date: Jan 2013       06-30-2017, 11:00 AM Reply
Ace Hardware has all the dookickeys other stores don't as well
Old     (Laker1234)      Join Date: Mar 2010       07-03-2017, 12:38 PM Reply
I found one!!! The ACE Hardware here remodeled over the winter and I did not know that they had added a larger O-Ring selection. Thanks for all of the input.
