Old     (chopper515)      Join Date: Mar 2005       03-31-2016, 3:50 PM Reply
Will the weight of the bag crush the pump and/or hose if I set the pump in the back on the floor like this? It will be a 600 sumo sac in 2001 Tige 2100V.
Old     (bcrider)      Join Date: Apr 2006       03-31-2016, 4:20 PM Reply
It ultimately depends on how much the sac fills that area. I notched the back panel on my VE.
Old     (chpthril)      Join Date: Oct 2007       03-31-2016, 4:37 PM Reply
I prefer to not have the pump wedged between the sac and back wall. i would look to move the battery back a couple inches and then pass the hose through the wall to the pump like Dave's pic.
Old     (chopper515)      Join Date: Mar 2005       03-31-2016, 6:30 PM Reply
Yeah I know its not ideal but if/when I put 2 batteries behind the panel, there wont be room for the pump. I'm thinking I might run it diagonally through the back wall then through that small wall separating the batteries from the engine compartment. It would sit just rear of the water separating filter.
Old     (duffymahoney)      Join Date: Sep 2008       04-01-2016, 8:01 AM Reply
You should be able to push the battery back and gain enough room for the pump back there. I would vent and drain to the opposite side as well.
have you checked out www.tigeowners.com?
Old     (bcrider)      Join Date: Apr 2006       04-01-2016, 8:35 AM Reply
My batteries are back there too.
Old     (chopper515)      Join Date: Mar 2005       04-01-2016, 10:24 AM Reply
duffymahoney, I'm on tigeowners too. I just thought I'd reach more people on here.
I don't think I have enough room to push my batteries back. I'll look into it.
Old     (chpthril)      Join Date: Oct 2007       04-01-2016, 2:30 PM Reply
What about turning them sideways? I no this if the STBD side, but the pump can lay right between the batteries of you can turn them.
Old     (chopper515)      Join Date: Mar 2005       04-01-2016, 7:47 PM Reply
Since I currently only have one battery, I decided to punch through the back wall. Whenever I get a second battery, I'll just have to figure out where to put it.
