Old     (petrie141)      Join Date: Jun 2012       07-22-2016, 9:24 PM Reply
We purchased a battery tender junior today and got a little confused when reading the instructions. It says that if you have the battery outside of the vehicle, you have to attach a 24" (minimum) 6 gauge insulated battery cable to the negative terminal. Then, after you've attached the positive clamp to the positive terminal, you attach the negative clamp to the open end of the 6 gauge cable. Is that last really necessary? Can you just use the negative terminal instead of having another cable? Anyone have experience with this?
Old     (Paul_42186)      Join Date: May 2013       07-24-2016, 3:37 PM Reply
That instruction is there to keep any spark that might occur away from the battery. In certain circumstances, a spark near the battery can cause an explosion. I usually connect the battery charger before plugging it in to power. That greatly reduces the explosion risk. When disconnecting the charger from the battery, I unplug the charger from power first.
Old     (jmanolinsky)      Join Date: Dec 2005       07-25-2016, 10:02 AM Reply
What Paul said.
