Old     (Brandin10)      Join Date: Jul 2015       07-25-2015, 10:12 AM Reply
Can anyone explain to me why it's harder to get a nice clean wake on the goofy side? Does it have to do with prop rotation? My boat is a 2015 Supreme S21
Thank You
Old     (OneCent)      Join Date: Jul 2010       07-26-2015, 2:51 PM Reply
Strange - most boats i know its easier on the goofy side - and yes, because of the prop rotation and the weight of the driver.
Old     (you_da_man)      Join Date: Sep 2009       07-27-2015, 6:10 AM Reply
Goofy side is easier on most boats to get a clean, better wake.
Old     (wakedaveup)      Join Date: May 2012       07-27-2015, 6:12 AM Reply
If you have LH prop rotation then naturally your port/regular side would be the cleaner wave. Prop rotation typically dictates which side is cleaner unless you really manipulate it with weight or a surf system
Old     (granddaddy53)      Join Date: Dec 2013       07-27-2015, 8:27 AM Reply
Have you tried 9.8 or less than 10 miles an hour. My wake is always good on my axis, but only perfectly clean when we go 9.8, whole face of wave like butter with zero white wash and slightly taller.
Old     (gator808)      Join Date: Jun 2014       07-27-2015, 5:32 PM Reply
may find out better ways to setup your goofy side at centurioncrew.com
They have a section just for supreme owners. All I know is it needs a lot of weight.
Old     (2500HD)      Join Date: Jul 2015       07-28-2015, 6:57 PM Reply
My experience with to left hand prop boats 1 being a supra saltare and the second being a supra santera is that the tracking fins are the culprit and not the prop rotation. The fins on older boats are set by hand and if they are skewed one direction or the other it will dictate the good surf side.
Old     (2500HD)      Join Date: Jul 2015       07-28-2015, 6:58 PM Reply
For the record both boats favored the starboard, or goofy side
Old     (Brandin10)      Join Date: Jul 2015       07-28-2015, 10:29 PM Reply
Thanks. I'll check out that site
