Old     (chris_schweda)      Join Date: Dec 2006       07-23-2018, 9:22 PM Reply
What prop are you guys running? I have a 2015 g23 with the 450 I currently have the stock 2561 and with full ballast and a boat full of ppl it struggles to wakeboard I pulled prop off and I will get it worked I was also looking at the OJ I have not read anything about anyone using 1 I did go with the oj on my 2013 and it did well just Have not heard anything on the 2:1 and the 17x17 OJ
Old     (jonblarc7)      Join Date: Jul 2006       07-26-2018, 6:06 AM Reply
I'm no help because I don't have a G23 but I'll bump your thread because I want to know the answer. I'll be looking for a used G23 in the next year or two. Ruining a smaller engine with a bigger prop has always worked for my needs. If I could find a 550 in my budget I would get it. But that's like finding a needle in a haystack at the price I want a G for.
It's like wakeworld has complete gotten away from the upgrading props, ballast and even sound systems.
Old     (Tallredrider)      Join Date: Mar 2011       07-26-2018, 12:31 PM Reply
It is probably a worthy discussion, but I am not sure if I would expect a whole lot of difference between two different 17 X 17 props, just different manufacturers. They can adjust the cup, but the bulk of the thrust is provided by the diameter and pitch nonetheless.
I am sure that OJ would let you test one out and return it as long as you don't ding it, for just the price of shipping. Relative to the price of the purchase, that is chump change to be sure you have the best prop for your usage patterns.
Old     (DatTexasBoy)      Join Date: Aug 2012       07-28-2018, 6:11 AM Reply
I bought a 17x17 from Eric and it was OK. I called Eric told him what it was doing and he said send it back. I am not sure what he did to it but once I got it back it out performed my ACME 17x17.
Fully loaded with 600# lead (OJ Prop)
Wakeboard 4100 rpm
Surf 3250-3300 rpm
Old     (chpthril)      Join Date: Oct 2007       07-28-2018, 4:39 PM Reply
Probably made it a 17 x 15.
Old     (chpthril)      Join Date: Oct 2007       07-28-2018, 4:55 PM Reply
A prop that floats, would be good.
Old     (cedarcreek216V)      Join Date: Aug 2011       07-28-2018, 6:07 PM Reply
I was going to say is it wrong to say one that just stays on!
Old     (Fbeltrao)      Join Date: Sep 2017       07-29-2018, 1:46 PM Reply
Acme 2749, what is the altitude where u ride? Lower pitch 14 but should put the boat to plane faster
Old     (fizzz)      Join Date: Nov 2010       07-30-2018, 6:23 AM Reply
hes in new orleans
chris my neighbor has a 2017 g23 with the 450 and hes running the acme 2569, it seems to work great. only time it wouldnt get on plane was wakeboarding with full ballast and like 14-15 people. we dropped the weight to 2000 and it was good to go.
Old     (chris_schweda)      Join Date: Dec 2006       07-31-2018, 8:56 AM Reply
I went with the OJ 970 it seems to work better that the acme I had yet I have not had 15 ppl in the boat with full ballast
Old     (chpthril)      Join Date: Oct 2007       07-31-2018, 9:26 AM Reply
Whats the cup on the 970? Cant find it listed.
Old     (DatTexasBoy)      Join Date: Aug 2012       08-06-2018, 11:40 AM Reply
I would not think this was the case since it lowered the RPMs on surf and Wake. Im sure it was some type of cup change.
